Author Topic: Keihin carb nut. Will devcon work?  (Read 3004 times)
Offline Paul552
  • HEAVEN #552
« on: September 22, 2014, 08:03:34 pm »
Just found a pin hole leak in the bowl nut on the carby on the cr 80 I am restoring.
Question is where to find a replacement nut?
Or
Has anyone tried devcon on a carb???? Will it hold fuel????
Offline matcho mick
    • Moto Tumbi
Re: Keihin carb nut. Will devcon work?
« Reply #1 on: September 22, 2014, 08:22:44 pm »
i used that black/grey mix it together epoxy metal repco sells in a small tube,(resiweld??)to repair a corrosion hole in a delorto bowl nut ,been ok for quite a few years now,guess devcon would be the same,only can you get it in small amounts??,hth, :P
Offline CRTAD313
« Reply #2 on: September 23, 2014, 07:26:15 am »
Can be found on eBay, not that pricey. Not worth fixing
Offline Paul552
  • HEAVEN #552
« Reply #3 on: September 23, 2014, 08:09:43 am »
I couldn't find them only the billet ones??
What are they called?? Bowl nut?? Carb bowl nut??
Offline rocketfrog
« Reply #4 on: September 23, 2014, 09:07:19 am »
Try also "Main Jet Cover" in your search. Should be common as muck, what model carb is it for specifically?
