Author Topic: Bottom and top end rebuild parts for 79Model PE250  (Read 1810 times)
Offline davidsonclan5
« on: September 17, 2014, 06:17:36 pm »
I'm after all parts required to rebuild the bottom and top end of a 79 model PE 250 Motor, where would be the best place to look here our overseas. Have not had much luck on ebay.
Con-Rod
Crank seals
Big end bearings
Over sized Piston kit
Cheers Rob
DAVIDSON'S MOTORCYCLE TRANSPORT
0405 838 583
[email protected]
Offline mick25
  • Hunter valley NSW
Re: Bottom and top end rebuild parts for 79Model PE250
« Reply #1 on: September 17, 2014, 06:35:03 pm »
Try alpha sports usa.  Or suzi spares south Australia but he can be a bit rude and some items are top dollar
« Reply #2 on: September 17, 2014, 06:57:40 pm »
Most of the parts you are looking for are still available over the counter at your local Suzuki outlet .
Rod - shims - pin -  B/E & S/E   Bearings  ;)
Bearing's  .... Buy them at your Bearing supplier and don't forget to ask for C3
seals    ... crank seals buy LHS & RHS from Suzuki, the rest from Bearing supplier ** note gear      selector and clutch  actuator shaft  seals are PBR  ;)
Piston Kit .... Flea bay - wosner or wiseco
gaskets  .... buy a  hollow punch kit  ( 6mm to 19mm  and some gasket paper ( .6mm )
« Reply #3 on: September 18, 2014, 09:45:23 pm »
Gaskets are available from Suzuki, get your Suzuki dealer to get a Woosner piston kit in for you. Put a carbon reed petal in it.
« Reply #4 on: September 19, 2014, 10:09:00 am »
Paul Miller, but be patient ;)
