Author Topic: 1984 KX500 Engine question...  (Read 7399 times)
Offline Hardo
« on: September 16, 2014, 10:17:57 pm »
Gday guys...
I am building this KX500 - from a bucket of bits ...
And I can't for the life of me figure out what exactly fits into the threaded hole I am pointing to with the scribe in this pic....
And of course I dont have any parts left over that could go there.........
Do any of you KX'perts have the answer for me please?
I just cant see anything on the parts diagrams anywhere......
Help !
Hardo...
Re: 1984 KX500 Engine question...
« Reply #1 on: September 16, 2014, 10:22:00 pm »
Had a look at a parts listing?
« Reply #2 on: September 16, 2014, 11:00:41 pm »
Isn't the internal forward "shift rod" that the forward "shift fork" slides on directly behind that hole?
Can you see the end of the shift rod through that hole?
Is the bore of the hole threaded or plain drilled?
« Reply #3 on: September 16, 2014, 11:06:04 pm »
Where you are holding your scriber,,,,is that outer end surface just still plain cast surface finish or has it been machined
(spot faced)?
« Reply #4 on: September 17, 2014, 07:15:18 am »
It may be there for assemble use at the factory.
Offline Hardo
« Reply #5 on: September 17, 2014, 07:50:26 pm »
Just realised my 500th post was regarding a 500... ironically...   :o
Okay - Nath.... I did say I have checked the parts manuals mate. I cant see it anywhere in them !
Mick D - to answer your Q's...
No you cant see the shift fork rod through that hole.
The bore of that hole is threaded.
The outer surface is plain cast........
I am no closer..... but thankyou for the questions.....  :-\
Does anyone know? surely someone that has an 84KX500 engine must know.  :(
Offline smed
« Reply #6 on: September 17, 2014, 08:20:16 pm »
I think you are missing the plate in this diagram 13676?   http://www.bikebandit.com/oem-parts/1984-kawasaki-kx500-kx500a/o/m150461#sch87314
Offline Hardo
« Reply #7 on: September 17, 2014, 09:11:29 pm »
Thanks mate...but no.
Bikebandit has the wrong diagram there for the 1984 KX500. That picture shows the 1983 KX500 setup. I know because I actually have both.  :)
I like your input though smed and appreciate anyone trying to help me here.....
Offline Hardo
« Reply #8 on: September 17, 2014, 09:18:33 pm »
it's like this one....
http://www.bikebandit.com/oem-parts/1984-kawasaki-kx500-kx500a/o/m150461#sch87540
And no it isnt plate 13169 as that is fitted on the inside of the case to hold the shift drum in place.....
I dunno.....   :o :o :o :o :o :o :o :o
Offline OverTheHill
« Reply #9 on: September 17, 2014, 11:47:32 pm »
I wonder if it's for a crank [pushing out] puller--if makes sense. Pic is of a KX500 so it says. If it was yamaha they generaly have two 8mm threaded holes opposite each other but i suppose why not have 3 holes of 6mm--if there's anywhere on the right side to screw the other two legs. Hope these links work to copy n paste--don't realy know what i'm doing.
http://www.oem-cycle.com/images/dscn2288.jpg
http://www.oem-cycle.com/images/dscn2289.jpg
Offline OverTheHill
« Reply #10 on: September 17, 2014, 11:50:28 pm »
actualy they look more like 8mm bolts but would have thought 6mm threads for the mag cover holes so--i dunno.
« Reply #11 on: September 18, 2014, 09:13:26 am »
If it were intended that anything was to be screwed flat to it, it would be machined flat instead of left as cast.
No parts list views or indexes show anything as missing from there.
Pictures instead of the real thing, slight disadvantage,,,,,,,,,,,,,,,,,,
It still looks to me that the end of the forward shift rod is directly behind that Threaded hole?? ??
If the threaded hole were to be perfectly over the end of the forward shift rod?? it would be the perfect place to wind in a "jacking screw" as a facility to separate the center cases.
It would be nice to have closure, but I ouldn't worry too much about it Hardo,,
Do what you do best ;D ;D
fuel it up and ring its neck ;D
« Reply #12 on: September 18, 2014, 09:43:51 am »
I see in the case of the "rear" shift rod, that its mounting bore has a smaller dia hole all the way through,,
nice access for a pin punch if it were needed?
Anyhow have a great weekend, I am going motorbike riding :D
for only the second time this year,,,got my priorities wrong me thinks
Hoorooo and good luck
« Last Edit: September 18, 2014, 10:39:52 am by Mick D »
