Marketplace
For Sale
TM250 ignition
Topic: TM250 ignition (Read 4854 times)
Gerard De Ruyter (Twistandshout)
A-Grade
TM250 ignition
September 15, 2014, 03:20:45 pm »
Not sure what year, can supply pic if needed (if it changed across models). But complete stator plate, internal rotor and wiring/plug. Never used it as didn't fit intended recipient ('69 TS250), but seller told me worked fine. $250 ono.
A-Grade
Re: TM250 ignition
October 01, 2014, 11:24:38 am »
$200??
Simo63
Re: TM250 ignition
October 01, 2014, 01:22:36 pm »
Is this the one I sold you a few months back? if so I can guarantee it works as I fitted it to my TS250 and it fired right up.
Dono113
Re: TM250 ignition
October 07, 2014, 07:42:25 pm »
My ts250 69 model s running a TM
building up my spare motor and could be chasing another TM system you still got it twisty?
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
A-Grade
Re: TM250 ignition
Reply #4 on:
October 13, 2014, 08:47:08 am »
Yes, still got it. If you want it to fit the '69 TS250 crank, you'll need to machine the crank a bit to give it all the taper length needed to fit the TM ignition. Not a hard job, but you'd need to have the crank out of the engine. Intrested?
Marketplace
For Sale
TM250 ignition
