Author Topic: YZ250S 1986 parts.  (Read 1308 times)
YZ250S 1986 parts.
« on: September 11, 2014, 07:55:10 pm »
Motor has 'gone boom' and is a real mess - torn the little-end eye open, for example... Cases seem OK, crank seems OK (obviously needs a new rod kit), gearbox seems OK - everything else is damaged to some extent, or missing.
All the major ignition components are there. Gotta assume they're working, considering the blow-up.
Forks. Rust on RHS leg (in seal area), LHS leg is good. Both lowers are fine.
Front hub, no brake rotor.
Front caliper seems fine.
Rear wheel is OK. Rim cracked on join, but appears straight and free from flatspots. Spokes rusty but usable. Hub seems good but needs bearings.
Rear brake plate has small section broken out, still usable.
Pipe is rough in the header, belly is OK. No muffler.
$180 for the lot, will sell seperately.
Located in Yass, southern NSW. Can post individual items, or bring to Show & Go on the Saturday or Cookardinia on Sunday. Sydney also a possibility.
Nathan. 04000 23847
On hold, pending payment.
« Last Edit: September 11, 2014, 09:03:07 pm by Nathan S »
