Author Topic: Resistive plugs Vs resistive plug cap  (Read 3013 times)
Offline Andrew L
« on: September 09, 2014, 09:18:52 am »
On my Ts250x It has a resistive plug BR7ES listed as required and what looks like non-resistive cap , if I change the plug cap to a resistive cap can I run normal non-resistive plugs B7ES as I have a collection of varying ranges in this type.cheers Andrew
Re: Resistive plugs Vs resistive plug cap
« Reply #1 on: September 09, 2014, 06:59:18 pm »
yes no problems
Offline Andrew L
« Reply #2 on: September 09, 2014, 07:46:21 pm »
Thanks I thought it would be plausible but best to get a second opinion instead of a hole in a piston
Offline PEZBerq
  • Brisbane
« Reply #3 on: September 09, 2014, 08:18:36 pm »
I thought resistive plugs and caps were to suppress electrical noise and nothing else? Have I been wrong again all these years  :o Not sure it is going to make any difference to piston life.
