Author Topic: modern-ish front brake lever assembly  (Read 2029 times)
« on: September 08, 2014, 08:17:25 pm »
I'm after a modern-ish hydraulic front brake lever assembly that will fit fatbars. Doesn't have to be pretty as long as it works, and cheap, as I'll be cutting it up :D
Offline rocketfrog
Re: modern-ish front brake lever assembly
« Reply #2 on: September 08, 2014, 09:07:58 pm »
wrong size handlebars though. I'd prefer genuine anyway. thanks though
« Reply #3 on: September 08, 2014, 09:50:31 pm »
Fatbars are 1&1/8" (I think) at the clamps, tapering to 7/8" (22.2mm) at the handlebars themselves.
7/8" has been the standard for a long time, with the exception of some middle age poser bikes which run 1". No doubt there's some oversized, over-blinged junk available in 1" if that helps?!
I don't understand what you're trying to achieve.
Offline rocketfrog
« Reply #4 on: September 08, 2014, 09:51:34 pm »
Aren't Fat bars still 7/8 at the ends?
Offline Andrew L
« Reply #5 on: September 09, 2014, 12:00:10 am »
Yep
« Reply #6 on: September 09, 2014, 05:43:35 am »
Sorry having brainfade, i was thinking back to when i bought my barkbusters and had to get them to suit bigger bars, obviously they clamp onto the bigger section of bar  :o
Offline YZ250H
  • Back in QLD Baby !
« Reply #7 on: September 09, 2014, 07:12:15 am »
What are you up to now fella  ???
Whatever it is I'm sure its a good idea  :o
