Author Topic: 83/84 model XR500  (Read 5644 times)
Offline steve234
83/84 model XR500
« on: September 08, 2014, 10:36:42 am »
G'day folks,
Looking for an 1983/84 XR500. I'm on the sunshine coast so if you have something you no longer want let me know. Basically chasing rolling chassis and engine. not interested in road gear, forks and plastics etc.
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline The Wombat
  • I think I can I think I can
Re: 83/84 model XR500
« Reply #1 on: September 08, 2014, 02:18:27 pm »
Hard 2 find a Rolling Chassis with no forks  :o
Simo63
« Reply #2 on: September 08, 2014, 02:20:52 pm »
G'day folks,
Steve
I'm on the Sunshine Coast and have an 85 XR500 roller frame with airbox. No motor though. Any help?
Offline steve234
« Reply #3 on: September 08, 2014, 02:21:48 pm »
Yeah won't be rolling to good eh!
Bultaco M106 Astro
Offline steve234
« Reply #4 on: September 08, 2014, 02:24:26 pm »
Simo,
I'll do some research on the 85. Was hoping to make a pre 85 but not really necessary. Main thing I require from the XR frame is the 83/84 geometry had the rake at 25.5 degrees which is perfect for what I want to do.
Steve
Bultaco M106 Astro
Offline Hardo
« Reply #5 on: September 08, 2014, 06:37:09 pm »
Hey mate - pretty sure the 85 XR is actually an XR600, not 500.
The XR500 last model was the RE 1984.
Happy to be corrected - but I just built an 84 XR500 so feel quite confident.
Cheers.
Offline mick25
  • Hunter valley NSW
« Reply #6 on: September 08, 2014, 06:46:15 pm »
Cheers.
yes you are right hardo  ;) see you going evo class aswell 8)
Simo63
« Reply #7 on: September 08, 2014, 09:54:30 pm »
Cheers.
Shit you're right Hardo .. what was I thinking??  Must be the medication I'm on for the Flu.
Sorry Steve, it's an XR600 roller so definitely no good for you.
What are you building?  I have a bunch of XR500RC's as I reckon they are a better motor that the early RFVC motors.  I run disk brake front end on my race one but aside from that it's fairly stock and it's a good thing to ride.  Will be better when Noel rebuilds my White Power shock for it :)
Offline steve234
« Reply #8 on: September 09, 2014, 09:05:01 am »
Simo, looking at a building a dirt track bike. Was reading about the dual carb setup and the steering rake on 83/84 models and it sounded like an easy/suitable build. No need for deraking the frame and little or no bog in the engine performance.
Looking for some RZ350 forks to keep it pre 85 also. I'll run a disc up front. Two wheel sets 21/19 & 19/19.
There is some TT bits in Bundy that would make a good start that I might look at also. But that will require frame mods.
Bultaco M106 Astro
Offline mick25
  • Hunter valley NSW
« Reply #9 on: September 09, 2014, 07:12:27 pm »
Steve the XL500 79,81 has a steep steering rake 26 deg no need to change it , The XL500 wheel base is 1400mm same as a jawa ,gooden specs
then put some 36mm early XT,TT500 inline forks on it  ;) .
 and the alloy TT500 model swingarm will work on the frame to, for some weight saving and some shine 8)
Put a XL185 tank on it aswell.
 then wack a champion or XR750 seat guard combo on it , they are a cheap dirt tracker plenty of parts out there and cheap as chips, and they seem to honk along aswell .
Simo63
« Reply #10 on: September 09, 2014, 09:38:45 pm »
I have a spare 82 XL500RC roller if that's of any interest.  First of the pro-link XL's and has 21" front wheel and square steel box section swing arm already
Offline steve234
« Reply #11 on: September 10, 2014, 05:56:45 am »
Holly shit mick25 have you been going through my stuff! I've got a TT front end and a mint XL185 tank. You've just saved me some $ haha. Evo here we come!
I'm definitely after the 25-26 degree rake, not sure how you would pull the 82 back not being a cradle frame. Open to suggestions!
Bultaco M106 Astro
Offline mick25
  • Hunter valley NSW
« Reply #12 on: September 10, 2014, 07:02:34 pm »
You would have to have the engine in the frame to keep the down tube in place ,while you cut the head stock and then take measurements from diffrent spots on the frame to make sure it gos back on straight and square and use a string line or alloy straight edge to keep the head stock straight and in the middle of the frame , I have deraked a TT500 and DR500 in the pass with no probs..
« Reply #13 on: September 10, 2014, 07:33:01 pm »
You can change fork rake by using a various triples with different offset's. Buy a digital level from flea pay would be a starting point.
http://www.ebay.com.au/itm/Digital-Level-Inclinometer-Angle-Finder-4-x-90-0-360-Quadrants-Spirit-Level-/151385768985?pt=AU_HandTools&hash=item233f4b8419
