Author Topic: Tarting up a Ts 250 motor  (Read 2393 times)
« on: September 07, 2014, 04:51:59 pm »
Motor started life as  a Ts 250 1976 ... which is ideal for dropping a Rh 250 barrel onto  ;)
Oil pump is no longer required as I have drilled the LHS side casing to allow for bearing lubrication... 76 models have it cast in but not drilled  ;)
 I have opened up the area were the pump was encased  and re-braced it,   filled in both tacho and pump drives holes.
Black pen marks show casting marks .... not cracks  ;)
« Last Edit: September 07, 2014, 07:08:19 pm by oldfart »
Re: Tarting up a Ts 250 motor
« Reply #1 on: September 07, 2014, 05:06:43 pm »
Next I added extended were the engine number is stamped to allow for a sprocket cover / case saver .... PE / Rm style  and welded on a mounting tab
Just above the Needle roller another tab has been added , but you need to allow for removal of cover in future'
Mag area has had two tabs added also to allow for an adaptor plate.... bottom @ 5 o'clock  and top at  2 o'clock
 pic is up side down  ::)
« Last Edit: September 07, 2014, 05:14:28 pm by oldfart »
« Reply #2 on: September 07, 2014, 05:11:43 pm »
Im sensing another special  Stewy. Sounds like you have been thinking about this one for awhile.
« Reply #3 on: September 07, 2014, 06:35:07 pm »
Use a TS cylinder Stew you won't regret it, sell the RH cylinder and buy a new commodore with the proceeds  ;)
« Reply #4 on: September 07, 2014, 07:07:08 pm »
 Lozza   Ok   I'll send one down so you can do your number on it, as it will go in another motor I have sitting on the bench .
This one has had the studs altered to match Rh barrel.
Shane this is another of those fill in jobs ( gunna happen ) till I sort the SP 511 Rod out.
« Reply #5 on: September 07, 2014, 08:00:41 pm »
keen on this one. ;)
