Author Topic: Found/Lost  (Read 8514 times)
Found/Lost
« on: July 05, 2008, 05:20:14 pm »
Found behind the ignition cover of 1974 XL350. :o
Where is it from? top somewhere  ::) ??
its a bit bigger than a pea.
Flat on top and one side.
« Last Edit: July 05, 2008, 05:53:08 pm by vmx247 »
Doc
Re: Found/Lost
« Reply #1 on: July 05, 2008, 07:01:29 pm »
if someone had said they found it in the clutch cover i'd be saying check the kickstart assy as it looks like the end from the positive stop. Maybe from the lower end of a broken cam chain guide that was replaced previously and they couldn't be bothered fishing it out or simply didn't know it was there. Is it steel or alloy?
Offline gorby
Re: Found/Lost
« Reply #2 on: July 05, 2008, 07:55:24 pm »
it could be a piece from the bob weights on the mechanical advance?
Re: Found/Lost
« Reply #3 on: July 05, 2008, 08:28:49 pm »
Doc,its a steel piece.
gorby haven't looked there ,thanks
I have just help take motor out of frame and have taken head & barrel off etc, the head/barrel wouldn't come out in the frame,the f... word was used only once, mind ;D
cam chain bits/guide good,
can't find anything wrong or missing yet.
tucker time, maybe find it tomorrow.
thanks
« Last Edit: July 05, 2008, 08:35:24 pm by vmx247 »
Offline holeshot buddy
  • sunshine coast qld
Re: Found/Lost
« Reply #4 on: July 05, 2008, 10:43:31 pm »
I THINK YOU BETTER SEND IT TO
BALLISTICS LOOKS LIKE
A 40 CALIBRE ;D ;D
follow me to first turn
Re: Found/Lost
« Reply #5 on: July 05, 2008, 11:13:25 pm »
If the bikes running ....toss the bugger over ya back fence...................... ;) seriously that is a fair lump better investigate ,and could you tell us if you find what it is/was. :) tim
« Last Edit: July 05, 2008, 11:23:48 pm by Tim754 »
Re: Found/Lost
« Reply #6 on: July 06, 2008, 12:13:31 am »
The bike was running,only discovered this bit of shrapnel due to the sidecover gaskets leaking a wee bit, so was replacing them  :o
Re: Found/Lost
« Reply #7 on: July 06, 2008, 12:56:19 pm »
the sun has risen once again and today brings another of lifes mysterys. ;D ;D ;D
He's given up....doesn't know where its from....
thanks folks
Offline Wombat
  • Gold Coast hinterland
Re: Found/Lost
« Reply #8 on: July 06, 2008, 05:28:49 pm »
Shirts with buttons have spare buttons attached - maybe just maybe it's a spare tooth...
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
Offline gorby
Re: Found/Lost
« Reply #9 on: July 06, 2008, 06:05:16 pm »
If it was in the top points cover,then it probably is nothing to worry about.
If it was found in the bottom round cover over the flywheel then I think it looks like a dog from one of the gears (which is an XL350 weakness ) :(
Re: Found/Lost
« Reply #10 on: July 06, 2008, 07:47:49 pm »
Spot on Gorby we had to do some large repairs on our old XL350racers for just such events , and it does look very much like the mentioned mauled puppies too. >:(
Re: Found/Lost
« Reply #11 on: July 06, 2008, 09:18:04 pm »
Didn't really want to split the motor :-\
suppose, got top off might have a look at the bottom.
Is strange where I found it, it was behind the fly wheel cover which is sort of seperated from gear box section.It would of had to do some jumping to get where it was.
Found nothing else ,,bugged if I know how it got there from the gear box
six pack of beam should see the job done.
steve
Tim ps looks like we are going to take three wheels this weekend and not two.
pps did some shit hot tuning this arvo,Norton pulls like a sixteen year old.
Re: Found/Lost
« Reply #12 on: July 08, 2008, 07:49:18 pm »
 Pulls like a Sixteen year old Male or Female?? :D Steve and Allison good luck , be careful enough to ride just outside your perceived limits and enjoy my friends!!!!!!!!!!!!!!!!!!!!!
Re: Found/Lost
« Reply #13 on: July 09, 2008, 09:19:54 pm »
Gorby wins the money,fourth gear is minus a dog.
cheers steven & alison WA
ps anyone got a spare 4th counter shaft gear for XL350 73
Offline gorby
Re: Found/Lost
« Reply #14 on: July 10, 2008, 08:18:16 pm »
sorry about being correct :( I dont have any spare gears but can only pass on some advice passed to me from an older XL350 racer.
1.use the clutch every time,every gearchange
2.hold the clutch in for quite a while before putting it into gear
3.roll the throttle off a bit on jumps so the rear wheel is not spinning flat out when the bike touches down.
4.retain the original rear wheel (it has a cush drive in it )
5.If the gearbox is really bad then the bottom crankase and gears from a 76/77 model are a fraction
   stronger.
