Author Topic: TM400 Rear Hub Rubbers  (Read 2163 times)
Offline Toolboy
« on: September 03, 2014, 09:20:45 am »
Gday all,
I have replaced the rear hub rubbers on my TM400 but there still is some play on the sprocket mount when fitted.
40yrs of wear so Im wondering if anyone out there has fitted a shim behind the circlip to stop the play???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: TM400 Rear Hub Rubbers
« Reply #1 on: September 03, 2014, 10:12:25 am »
Done a couple of those, you have to machine the hub flange and then make up a new sleeve, a bit of farking around but have seen some bodgy repairs done. Chains make a mess when they come off.
Offline OverTheHill
« Reply #2 on: September 03, 2014, 02:18:52 pm »
Better off not to shim it up to stop the rocking or bad things could happen to the circlip & groove. Never done it but machining & sleeving sounds the cure, then you could shim the side clearance later without side loading said circlip. Comon problem on all my old trail Yamahas too. Give me my "68 DT1 with it's sprocket mounted on it's own bearing/stub axle thingy, fail safe that way plus you could change the wheel without loosing sprocket & chain etc. Buggered if i know why they changed it as wasn't heavy or anything.
