Author Topic: '77 WR250  (Read 6310 times)
Offline YUMASTEPSIDE
'77 WR250
« on: August 30, 2014, 11:07:27 am »
I'm doing up a '77 WR250 frame and need to know a couple of things, and as the frame has no forks or swingarm, the main things I need are measurements from a standard bike.
   I have built an alloy swingarm, so I need the distance from the pivot bolt to the lower shock bolt.......centre to centre.
I'm also fitting a different front end, and need the length from the axle centre to the bottom of the head stem of the frame, with no load.
  If anyone can help with these dimensions, it would be greatly appreciated.
                                    Roger
This is what I'm working on, but I no longer have the forks  ::)
« Last Edit: August 30, 2014, 11:11:54 am by YUMASTEPSIDE »
Re: '77 WR250
« Reply #1 on: August 30, 2014, 02:49:08 pm »
jump on to café husky and 500 punters will have one as a roller somewhere and will have all the details. 8)
Re: '77 WR250
« Reply #2 on: August 30, 2014, 04:47:22 pm »
That is pure blasphemy!
k
Re: '77 WR250
« Reply #3 on: August 30, 2014, 04:49:56 pm »
.............to each, their own ! 8)
                     Roger
Offline HVA61
Re: '77 WR250
« Reply #4 on: August 30, 2014, 05:34:09 pm »
Hey Rog
Thats a 76 frame ,75/76 triples , 75/76 forks and lue lue front wheel. All husky components
Is that the front end you are going to use.
let me know before i get you the measurements
regards
shoey
Re: '77 WR250
« Reply #5 on: August 30, 2014, 08:45:47 pm »
Thanks Rob, despite the certainty of death threats from the purists, I'm using all Yamaha running gear. I traded all the original gear, wheels; forks; swingarm; pipe and any other extraneous parts to a mate for an OSSA Phantom.......not a bad deal.....the motor had a rusted crank from sitting in a blokes back yard with no head on it, so I gave it to Snowy76 for parts.
  I need the dimensions to put the shocks back in the same spot as the original and the fork length to make it sit at the same height. I'm using a 17" IT465 rear wheel and 21" IT front wheel.
                                            Roger
Re: '77 WR250
« Reply #6 on: August 31, 2014, 06:50:10 am »
Looks like a interesting project. Keep us posted on the build. J
Offline HVA61
Re: '77 WR250
« Reply #7 on: August 31, 2014, 01:18:13 pm »
Rog
380mm
705mm to frame
or 685mm to bottom of the bearing cup
Rob
Re: '77 WR250
« Reply #8 on: August 31, 2014, 02:14:24 pm »
Thanks Rob, Snowy just rang me with pretty much the same measurements, so now I've got it double checked, I can work out which forks to use and TIG on the rear shock mounts.  ;D ;D ;D
                          Thanks again to all
                                         Roger
Re: '77 WR250
« Reply #9 on: August 31, 2014, 08:48:51 pm »
why a 17 inch rear?
Re: '77 WR250
« Reply #10 on: September 01, 2014, 08:14:29 pm »
..............apparently thats what HL's use.........and I had one  ;)
                      Roger
