Author Topic: TM 250 Pistons?  (Read 2458 times)
Offline Sorelegs11
TM 250 Pistons?
« on: August 28, 2014, 02:09:36 pm »
After nipping up my tm250 I have sourced another piston and rings, both from separate places.
The rings are almost twice as thick as the ones that were removed and are part #12140-15013-050.
Does anyone know what these rings may be for or did they change the thickness of them as the models progressed?
The piston pat #12110-30731-050 does not seem to be the same either.
I suspect I may have been sold a lemon (damn fleebay) but not knowing the correct part no's I should hgave done my homework.  ::)
Can anyone tell me the correct pat no for the thinner type rings and piston to suit, and what the parts i have might fit.
Cheers Darren
Knew I should have stuck with the yammies.
Offline sleepy
Re: TM 250 Pistons?
« Reply #1 on: August 28, 2014, 02:27:25 pm »
From the original parts book. 0.5 os piston is # 12110-30740. STD piston is # 12110-30731.
Rings 0.5 os # 12140-30710. The book covers models from J to M and all use the same parts.
Wossner list all sizes to suit TS250 from 73-81 which is the same as TM250.
Quick Google on the ring part # you have is TS250. From 1968.
« Last Edit: August 28, 2014, 02:33:20 pm by sleepy »
Re: TM 250 Pistons?
« Reply #2 on: August 28, 2014, 04:51:13 pm »
Darren in  your other post your were chasing  .025  now you have  .050   ::)
 Part # = 12140-15013-050
Part Description = RING SET,PISTON
Model Count = 10
T500 1968 492 T500 COBRA STREET
T500K 1973 492 T500 TITAN STREET
T500J 1972 492 T500 TITAN STREET
T500-3 1970 492 T500 TITAN STREET
T500R 1971 492 T500 TITAN STREET
T500-2 1969 492 T500 TITAN STREET
T500L 1974 492 T500 TITAN STREET
TM250-2 1970 249 TM250 RH67 OFF ROAD
TS250 1969 246 TS250 SAVAGE DUAL SPORT
TS250-2 1970 246 TS250 SAVAGE DUAL SPORT
Part # = 12110-30731-050
Part Description = PISTON
Model Count = 4
TM250J 1972 246 TM250 CHAMPION OFF ROAD
TM250K 1973 246 TM250 CHAMPION OFF ROAD
TM250L 1974 246 TM250 CHAMPION OFF ROAD
TM250M 1975 246 TM250 CHAMPION OFF ROAD
Offline Doc
Re: TM 250 Pistons?
« Reply #3 on: August 28, 2014, 05:36:26 pm »
The '69/'70 TS250/T500 and RH69/TM250 ran the extra wide rings. The rings you have are 12140-15700 and should have been in the old yellow/red suzuki boxes like these
http://www.ebay.com.au/itm/Suzuki-NOS-TM250-TS250-T500-1968-74-Piston-Ring-Set-12140-15700-S7-/250979912229?pt=Motorcycles_Parts_Accessories&hash=item3a6f918a25&_uhb=1
before purchase have the seller measure the thickness to know for sure ;)
I'd say someone has put older rings in a newer box when they may have had the same prob. Parts books/fiche will say they interchange to later 'normal' thickness piston/rings but only if the both the piston and rings are changed as a set. A little something Zedder/parts software can't tell you ;)
« Last Edit: August 28, 2014, 05:53:56 pm by Doc »
Offline Sorelegs11
Re: TM 250 Pistons?
« Reply #4 on: August 28, 2014, 05:50:13 pm »
Yes oldfart I jumped the gun and bought the .05 piston and rings before I tried cleaning the alloy out of the bore and rescuing the piston.
However the 0.05 piston and rings are not compatible and the rings are twice as thick as the ones I removed.
I am trying to establish what parts I actually have, and maybe get a new .25 kit as well.
Thanks everyone for the info.
Re: TM 250 Pistons?
« Reply #5 on: August 28, 2014, 07:22:59 pm »
Hacksaw the ring groove and tek screw it into place   ;)
