Author Topic: YZ125H - 1981 - parts - SOLD  (Read 1282 times)
Offline Pete F
« on: August 26, 2014, 12:28:43 pm »
A clean out of my shed has uncovered the following YH125H 1981 parts which I salvaged off a wreck a few years ago that I no longer need (originally I had the idea of using the swing arm, mono shock, triple clamps and forks on my 1980 "G").
Complete motor including kick starter -4V2- haven't pulled down so internals unknown. At very least should be able to salvage some parts. Cases are fine.
Triple clamps - look to be in reasonably good order with radiator port intact.
Set of 38mm forks to suit the triple clamps. Rust up top near triple clamps but sliding surface seems ok.
Monoshock
Swing arm
Frame rubber that goes under seat near where rear mudguard bolts on
Rear axle and chain adjusters
Assorted nuts and bolts.
$100 the lot. Pick up Chatswood, Sydney.
YZ125G owners may also be interested as the swing arm, mono shock and triple clams will fit on a "G" giving bigger front forks and slightly longer wheel base.
Peter
0418287310
« Last Edit: August 29, 2014, 11:08:45 am by Pete F »
Simo63
Re: YZ125H - 1981 - parts
« Reply #1 on: August 26, 2014, 01:22:35 pm »
SOLD .. I'll call you in a minute
