Author Topic: SC500 part numbers  (Read 4362 times)
Offline asasin
SC500 part numbers
« on: August 24, 2014, 04:08:52 pm »
Hi can anybody please give me the part numbers for SC500: piston pin , bearing and head gasket.Is there a equivalent ie yz490 etc. I have got around to assembling mine and have a fresh sleaved barrel to bore new piston STD and rings.but the other bits are not there.
John
« Last Edit: August 24, 2014, 04:13:38 pm by asasin »
If in doubt ,WIND IT OUT
Offline smed
Re: SC500 part numbers
« Reply #1 on: August 24, 2014, 04:37:07 pm »
http://www.partsfish.com/oemparts/a/yam/5004172cf8700209bc784aa8/crank-piston
http://www.partsfish.com/oemparts/a/yam/5004172cf8700209bc784aa4/cylinder-reed-valve
If you write down  the part numbers you want then go back to the start of the Yam OEM page you will see on the right "search by part number", put the number in & hit search,It will take you to a description of the part,click on "where used" & it should tell you what other bikes use that part :)
« Reply #2 on: August 24, 2014, 05:10:13 pm »
Asasin beware of using the US part # in Aust system they have 2 extra numbers on the end . These will just come up on the Aust Yamaha system as not known . just drop them in Aust . there are 2 standard pistons for the SC 363-11631-00-96 which is 94.96 mm or 363-11631-00-98 = 94.98 mm . Rings 363-11611-00 ring std . piston pin 363-11633-00 . little end brg 93310-22062 . head gasket 363-11181-00 .
Iain
Offline asasin
« Reply #3 on: August 24, 2014, 06:56:35 pm »
Thanks Ill try them at my mates Yamaha shop tomorrow . I have the piston and rings  , it looks like it was supposed to be a kit but pin and bering missing.
John
« Reply #4 on: September 25, 2014, 11:36:33 pm »
pin and bearing is same a TX650 i think, piston and ring are only off the 500, as is gaskets
Offline Viper666
    • Ballarat Rovers MCC
« Reply #5 on: October 02, 2014, 05:22:39 pm »
Try this site for Australian part numbers.
http://www.motorcycleland.com.au/yamaha_search.php
As already stated in above post
This Yamaha 363-11633-00 PIN,PISTON part is also used on these models and components:
1973 SC500 CRANK - PISTON
1974 SC500A CRANK - PISTON
1974 TX650A CRANK - PISTON TX650A - XS650B - C
1975 XS650B CRANK - PISTON TX650A - XS650B - C
This Yamaha 93310-22062 BEARING,CYL.#10 part is also used on these models and components:
GASKET, CYLINDER HEAD (363-11181-00) part is also used on these models and components:
1973 SC500 CYLINDER - REED VALVE
1974 SC500A CYLINDER - REED VALVE
