Author Topic: FOR SALE, KX250A5, excellent cond *** SOLD ***  (Read 7463 times)
« on: August 24, 2014, 01:02:02 am »
For sale, my second KX250A5, it seems a very low use bike, since doing the following work it has only done two 3-lap races at Viper last year and two 10 min sessions at my own track.
The only negative aspect that I could say about the bike is the chain had previously taken-out the original sprocket cover mounting lugs, hence the non original guard that I made.
The price is $4300, I will not be accepting any offers, it is worth the money.  I will not be changing the spec of the bike AND I will not be negotiating by email, I've already had confusion with someone by doing that.
For another $1000 I'll tip-in a spare complete engine.
* Fresh resleeve, new piston & rings.
* New plastics.
* New bearings & seals in crankcase.
* New wheel bearings.
* New swingarm bearings, seals & bushes.
* New headstem bearings.
* Near-new YSS rear shocks with comp & rebound damping adjusters.
* New .45 kg fork springs.
* New fork seals.
* New grips, Scott half-waffle.
* New fork boots.
* New PFR pipe & muffler.
* New RK X-ring chain & sprockets (alloy rear).
* New Unifilter airfilter.
* New tyres front & rear (never ridden on).
* New heavy-duty clutch springs.
* KDX cylinder head (fin dampers - quieter).
* 10mm less offset triple clamps (much improved steering & handling).
* New carb needle & needle jet.
* New alloy folding gearlever.
* Wide footpegs.
* Rubber bar mounts.
« Last Edit: October 14, 2014, 03:01:40 pm by John Orchard »
Re: FOR SALE, KX250A5 - $4300
« Reply #1 on: August 24, 2014, 08:24:25 am »
John
What gear lever did you use? Looks like a modern YZ. I need one for my 125.
« Reply #2 on: August 24, 2014, 12:01:27 pm »
you'll need the cash for fuel, tyres and chains for the 500 ;D ;D
« Reply #3 on: August 24, 2014, 06:04:25 pm »
John
Yep it's a spare that I had for a 2010 YZ250 that use to own.
« Reply #4 on: August 25, 2014, 12:29:16 pm »
I have a 09 250 two stroke and it looks the right shape , just unsure about the spline.
Did you like yours? Mine needed alot of jetting before it smothed out.
« Reply #5 on: August 26, 2014, 05:23:33 pm »
Did I like the bike? My KX did take a little bit of fidling to get it how I like it, basically went to new stock settings but a change to 6F21 needle.
« Reply #6 on: August 28, 2014, 05:44:31 pm »
Got another seat with new cover and less bumpy foam and an original front rim, lookin awesome I must say  :-)
Offline oldcol
« Reply #7 on: August 29, 2014, 09:35:59 am »
Hi John, Would you be interested in selling the original triple clamps if you still have them? Thanks Col.
Offline smed
« Reply #8 on: August 29, 2014, 11:12:23 am »
Just buy the whole bike Col, Ya know you want it :D
« Reply #9 on: August 29, 2014, 12:28:28 pm »
John how did you like the new YZ? I really like mine now but it took alot of set up.
Hope someone buys this bike soon as it's making my bank acount nervous.
« Reply #10 on: August 29, 2014, 06:07:56 pm »
I'll have a look and see if I can find them.
Offline oldcol
« Reply #11 on: August 29, 2014, 08:42:15 pm »
Thanks John, Let me know if you find them. Would like it in My shed Smed, much nicer than that RED stuff, Thanks Col.
Re: FOR SALE, KX250A5, excellent cond - $4300. Spare engine avail.
« Reply #12 on: October 14, 2014, 12:17:35 pm »
Still got the bike, the spare engine that I will let go with the bike for $1000 is available separately for $1500.  The spare engine has pipe, carb & complete electrics, it still has original sprocket cover lugs (might swap the engine with the one in the bike?)
I know this is a bargain, after just buying a couple of bikes that are suppose to be 'ready to go' and seeing the time & money they required to meet my 'ready to go' level.  To buy & build another A5 would cost you over $6500.
Re: FOR SALE, KX250A5, excellent cond *** SOLD ***
« Reply #13 on: October 14, 2014, 03:02:02 pm »
Bike is sold.
