Author Topic: 89 yz250wr  (Read 5404 times)
Offline Paul552
  • HEAVEN #552
89 yz250wr
« on: August 22, 2014, 09:22:58 pm »
What's the difference between the YZ and the YZwr (wide ratio)
Is it just the gear box? Or is the anything else different ?
Re: 89 yz250wr
« Reply #1 on: August 22, 2014, 09:58:34 pm »
Lighting coil, blue replaces red.
IIRC, there were more changes to later models (18" rear wheel, bigger tank), but they weren't applicable to the 89s.
Also, the 89 models were far more likely to have a compliance plate compared to the other pre-96ish models.
Offline Paul552
  • HEAVEN #552
Re: 89 yz250wr
« Reply #2 on: August 23, 2014, 04:47:16 pm »
Could you use for mx even with wr gearing or Nathan do you know if you can just change the gear set to YZ spec?
« Last Edit: August 23, 2014, 04:51:26 pm by Paul552 »
Offline smed
Re: 89 yz250wr
« Reply #3 on: August 23, 2014, 04:50:58 pm »
No probs ;)
Offline Ekka
  • Go hard or go home
Re: 89 yz250wr
« Reply #4 on: August 25, 2014, 07:02:19 am »
Softer springs in the forks and rear shock plus rubber mounted hangers
Offline popeye
Re: 89 yz250wr
« Reply #5 on: August 25, 2014, 10:20:12 am »
Only thing for MX, there is quite a big jump from 3rd to 4th gear....
Offline Paul552
  • HEAVEN #552
Re: 89 yz250wr
« Reply #6 on: August 29, 2014, 07:06:47 pm »
Does anyone know what the prefix for the vin would be for a 89 or how to identify by the vin
Re: 89 yz250wr
« Reply #7 on: August 30, 2014, 05:48:31 pm »
If it has a 17-digit VIN, then an '89 model's tenth digit will be a "K".
My 94 YZ has an old style frame number (rather than a 17-digit VIN), so I assume the 89s also have an old frame number.
Offline Paul552
  • HEAVEN #552
Re: 89 yz250wr
« Reply #8 on: August 30, 2014, 09:33:45 pm »
Thanks nathan
Offline Ekka
Re: 89 yz250wr
« Reply #9 on: August 30, 2014, 10:49:33 pm »
I'm too pissed to read or count the number on mine
