Author Topic: N.O.S PC pipe for CR125RE 1984  (Read 2096 times)
Offline Damo
Re: N.O.S PC pipe for CR125RE 1984
« Reply #1 on: August 21, 2014, 11:54:43 am »
Be careful with this, it does away with the ATAC canister and you need an adapter pipe to fill the void which is an accessory.
I cannot see it in his listing???
Offline smed
« Reply #2 on: August 21, 2014, 01:14:51 pm »
You are right,I have seen the PC pipes fitted to bikes both with & without the ATAC,They must have made 2 different pipes back in the day :-\,I have one on my 85 CR125 & it does away with the ATAC,The pipe was brought second hand & did not come with the adaptor, I made the original work by cutting off the ATAC chamber, I had a look on PC's website & you can actually still buy the pipes off them,Cheaper too 8) 8) 8) 8) http://www.procircuit.com/platinum-pipe-cr125r-84.html    It says nothing of using an adapter though, They still do one for the 86 also & it notes you must use an adaptor purchased separately :)
I had a DG pipe on my bike previously,It done away with the ATAC also but came with the adaptor ;)
This is a 86 US team bike,It has the ATAC fitted  :)
