Author Topic: 1984 TS250x  (Read 7993 times)
Offline TTezza
1984 TS250x
« on: August 18, 2014, 02:59:02 pm »
TS250x 1984, good motor, new swing arm bearings, frame blasted and painted. Needs front inner tube, front calliper seized and will need seal kit, air filter perished, rear light cracked lens, wiring harness not plugged in, rear brake cable needs threaded end welded back on. Has been dry stored for 18 years and only recently put back together, very low km's. More photos if needed, pickup only Newcastle area. Shed cleanout, need the room and the money, $500 ono.
« Last Edit: August 18, 2014, 03:15:49 pm by TTezza »
Offline TTezza
Re: 1984 TS250x
« Reply #1 on: August 18, 2014, 03:08:49 pm »
Offline Boyracer
Re: 1984 TS250x
« Reply #2 on: August 18, 2014, 05:08:24 pm »
Not bad for 500, would make a good little toy for somebody.
Offline Andrew L
Re: 1984 TS250x
« Reply #3 on: August 19, 2014, 12:26:43 am »
If only a bit closer I could add it to my other two probably just as well its in Newcastle and not Geelong.
Offline 2minutetim
Re: 1984 TS250x
« Reply #4 on: August 20, 2014, 10:12:27 pm »
 :) that thing looks a gem, would be a great vinduro weapon with Japanese reliability and suspension!
Shouldn't have trouble selling that Tezza, a couple of nights in the shed on the fizzy drinks and it would be a goer!
If I had a bigger shed I'd be over in a flash.
T
Remember, no matter what anyone says, size does matter!
Offline TTezza
Re: 1984 TS250x
« Reply #5 on: August 27, 2014, 06:04:48 pm »
Bump
Offline nelpd96
Re: 1984 TS250x
« Reply #6 on: August 27, 2014, 06:22:03 pm »
Mate, any chance you can get some good close photos of the decals for the tank and the radiator shrouds I am trying to get a collection of repro graphics going for these things.
Paul
Offline TTezza
Re: 1984 TS250x
« Reply #7 on: August 27, 2014, 06:34:50 pm »
Deposit taken
Offline TTezza
Re: 1984 TS250x
« Reply #8 on: August 27, 2014, 06:40:38 pm »
Paul,
     Hope this helps?
Offline nelpd96
Re: 1984 TS250x
« Reply #9 on: August 27, 2014, 07:21:47 pm »
Thanks if the new owner has any questions tell them to check.my build thread into the Suzuki section.
Offline TTezza
Re: 1984 TS250x
« Reply #10 on: August 27, 2014, 07:26:42 pm »
Paul,
      I told him to check out your thread and any questions someone on here would be able to help him out, thanks Terry.
