Author Topic: PE175 bit  (Read 2302 times)
Offline pecrazy
PE175 bit
« on: August 16, 2014, 02:38:52 pm »
Hi, Looking for one of these to fit an 83 PE175, goes in the rear brake drum then through the swingarm, also an axle as mine is bent but I can straighten that.http://rs1380.pbsrc.com/albums/ah196/plymoth1/IMG_1561_zps921e2f0f.jpg~c200 This is out of an 80 pe175 and is too short.
Offline pecrazy
Re: PE175 bit
« Reply #1 on: August 16, 2014, 02:51:10 pm »
Re: PE175 bit
« Reply #2 on: August 16, 2014, 10:04:28 pm »
Check out http://www.partzilla.com  and look up the schematic for the name and part No your looking for. This site will also tell you what other models used it which will all help with your search.
Offline VINDURO
    • VINDURO
Re: PE175 bit
« Reply #3 on: August 16, 2014, 10:21:04 pm »
I have used that website to do that for Yamaha parts, however in this case when I tried to do it for the model mentioned above (1983 PE 175) it only displayed AFTERMARKET parts.
Here is the schematic:
Is it part # 15 in the diagram above that you are after?
Jock
Offline pecrazy
Re: PE175 bit
« Reply #4 on: August 17, 2014, 06:29:17 am »
Hi, yes part number 15 plus the big nut that goes on it. Previous owner of this bike just put it together without it, cannot believe some of the things he has done to this bike or hasn't done.
Offline Doc
Re: PE175 bit
« Reply #5 on: August 17, 2014, 07:51:23 am »
Part # = 64761-14400
Part Description = SHAFT,REAR BRAKE DRUM
Model Count = 3
PE175D 1983 172 PE175 DUAL PURPOSE
PE175E 1984 172 PE175 DUAL PURPOSE
PE175Z 1982 172 PE175 DUAL PURPOSE
Re: PE175 bit
« Reply #6 on: August 17, 2014, 08:11:16 am »
 NLA ...... if you have access to a lathe they are easy to make.
