Marque Remarks
Yamaha
Yz 250H engine oil seals
Topic: Yz 250H engine oil seals (Read 2341 times)
loosecannon
Novice
August 16, 2014, 02:21:00 pm »
Can someone point me in the right direction for some engine oil seals for. 250H, I'd like to keep a full kit on the shelf, but a gear shift seal is the one I need first
Thanks in advance
Dave
tony27
Re: Yz 250H engine oil seals
August 16, 2014, 03:22:41 pm »
Should all be available from Yamaha still, same as the 465 & most likely 490, crank & sprocket seal kits are also done by all balls
August 16, 2014, 08:05:12 pm »
99% of the engine /gearbox bearings and seals are available from your local bearing shop at a fraction of the price you'll pay from Yamaha. You may find a bearing in there that can only be bought from Yamaha though.
loosecannon
Novice
August 18, 2014, 06:07:28 pm »
Excellent... Thanks for the help and info !!?....
Marque Remarks
Yamaha
