Author Topic: A friend has a DT250 1974, what is the best CDI to bolt straight in?  (Read 2962 times)
Offline oldyzman
  • 250 two stroke!
The ignition is not working and he wants to renew it, so he is after a simple bolt in...
Brett
Re: A friend has a DT250 1974, what is the best CDI to bolt straight in?
« Reply #2 on: August 11, 2014, 11:00:59 pm »
DT400 , mx 250,360, 76yz 250 ,400 , 78 yz400 dt400 will all fit . If you still want lights use the IT 's 76 77 78 400's . Iain
Offline Andrew L
« Reply #3 on: August 12, 2014, 12:19:52 am »
I have a REX,S unit for the dt400 not made for my application but I modified the the supplied plate to line up with my application ( RT3 360 )the advance curve is not great for a 2 stroke to say the least, I asked them for a map of the curve after a lot of messing about (pinging) and they told me they didn't have one and they guessed a bit (allot) about the curve , got it mapped by an independent mob and it wasn't that good Ill find it and scan it if you want to see it. It makes it run but Ive not had a great deal of success it starts allot easier without breaking my knee but that's about it.
