Author Topic: YZ465 Ohlins shock  (Read 4801 times)
Offline Viper79
YZ465 Ohlins shock
« on: August 09, 2014, 01:33:35 pm »
Hi,
I have an Ohlins shock for my YZ 465H and it has large sperical bearings in the mounts at each end.
Which obviously need some sort of sleeve or bush to adapt down to the standard mount bolt size.
Dose anyone know if such a thing is available or is it something I will have to get made?
Regards
Rob.
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
Re: YZ465 Ohlins shock
« Reply #1 on: August 09, 2014, 01:46:18 pm »
Would say you'd have to get something made, shouldn't be too hard. I would seriously doubt ohlins would still stock parts specific to the 465.
The ohlins importer here reckons the piston size is the same as current shocks & works out to be roughly 1/3 the price of a gold valve
Offline Viper79
« Reply #2 on: August 09, 2014, 06:14:03 pm »
Thanks Walter,
The bearings in the shock are 30mm OD and 17mm ID.
The front mount bolt and the rear pin appear to be 12mm, so I would need a bush to reduce the 17mm to 12mm or new bearings to suite. Do you have a solution..
Regards
Rob.
Offline ARN
« Reply #3 on: August 09, 2014, 08:53:15 pm »
hi rob
the Ohlin's shock from new I have has the same set up as standard Yamaha (it is a 30 year old shock which I had from new
), I do remember having to make sleeves as the hole was larger though
cheers Arno
Offline Viper79
« Reply #4 on: August 09, 2014, 09:34:24 pm »
Thanks Walter, I will check into the bearing thing.
Arno it's a shock that Bernie had lying around for years, as Walter suggested I might be able to change the bearings to suite.
Rob.
