Author Topic: Polishing lower fork legs (internal)  (Read 3448 times)
Offline Paul552
  • HEAVEN #552
« on: August 04, 2014, 07:00:09 pm »
Putting a set of 86 model forks on a 84 (disk brake) CR80
Drama is I have good Chrome on the upper tubes 84 and totally f'd 86 tubes.
I can't see why I can't use the 84 upper tubes in the 86 bottom tubes.
The 86 bottoms aren't great inside so I want to polish them up before using them
I was going to put them up in the lathe and scotch brite them.
Anyone else done this? Any better ideas ? :o
Offline SlideRulz
  • Not anti social just anti idiot.
Re: Polishing lower fork legs (internal)
« Reply #1 on: August 04, 2014, 07:10:34 pm »
Easy way out is to cut a slot in the end of a bit of round bar, 10-12mm.
Slip a section of fine emery strip into the slot and wrap around, using kero or some type of cutting fluid and your hand drill on a slow speed and correct direction, hone out the inner leg.
Rinse and repeat.
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: August 04, 2014, 07:11:00 pm »
You can get a large phillips head screwdriver or a piece of 12mm steel round bar tape the start of a bit of scotchbrite to it then wrap it round in the right direction put that into a pistol drill, you can use that to hone the inside of the lowers.
brett
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: August 04, 2014, 07:12:14 pm »
Similar to sliderules, we were typing at the same time....
« Reply #4 on: August 04, 2014, 07:12:28 pm »
Ball hone.
« Reply #5 on: August 04, 2014, 08:05:54 pm »
You can more or less do the same thing with the lathe except you turn the fork leg with the lathe and use the slotted bar on the tool post.
« Reply #6 on: August 04, 2014, 11:57:51 pm »
Have you checked fork diameter between the two ?
