Author Topic: Smits tacho gearbox/ KTT service?  (Read 7918 times)
Offline ola_martin
« on: July 28, 2014, 04:06:50 am »
Hello.
I'm after a Smits tacho gearbox for my Bultaco TSS.
It should be called BG1507/?
Someone called KTT service in Australia did them, but is not in buisness anymore, has someone continued the production?
Any other leads on where I can find one?
« Last Edit: July 28, 2014, 04:12:43 am by ola_martin »
Re: Smits tacho gearbox/ KTT service?
« Reply #1 on: July 28, 2014, 09:01:14 am »
KTT is long gone. Contact Lionel Otto Instruments.
Offline DR500
« Reply #2 on: July 28, 2014, 10:04:10 am »
Try Don, he probably  got boxes of them. http://www.newellmotorcycles.com.au/bultaco.htm
Offline ola_martin
« Reply #3 on: July 29, 2014, 09:03:09 pm »
Thanks.
I'll be impressed if Newell has boxes of TSS parts, but it would be great if he does. :D
Anyway, I tried the email on his site, but it bounced back, does someone have one that works?
Offline DR500
« Reply #4 on: July 30, 2014, 01:34:54 pm »
you best ring him
« Reply #5 on: July 30, 2014, 02:12:02 pm »
I just rang Don Newell for you, he doesn't have any....So I rang John at Lionel Otto Instruments, he is 99% sure he has one or can get one [knows where the old KTT leftovers went]. What he needs to know is the reduction [he thinks 4-1 ratio for that period] and is normal rotation or reversing. Where does it drive off. Cheers John.
Offline ola_martin
« Reply #6 on: July 30, 2014, 09:49:39 pm »
Wow!
Thank you very much John, so very kind of you to help out! :D
The gear runs right of the crank, it sits on the flywheel cover.
The flywheel turns counter-clockvise (same direction as the front sprocket)
The tacho has a 4-1 marking.
Maybe this also means something:
Bottom tacho:
I would also need the cable if he can supply.
Thank you very much again!
Offline yamayeeha
« Reply #8 on: July 31, 2014, 04:20:45 pm »
How long for the cable?. The pommy place might have the stuff from yamayeeha.
Offline ola_martin
« Reply #9 on: July 31, 2014, 07:20:04 pm »
The cable should be ca 75cm.
Measured on the outside of the cable-threads is slightly less than 12mm, on the tacho-clock.
Clock runs like normal I guess, clockvise vieved from the top, and counterclockvise when vieved from the cable-end.
Do you think I should ask at the other place?
« Last Edit: July 31, 2014, 07:24:34 pm by ola_martin »
Offline yamayeeha
« Reply #10 on: July 31, 2014, 07:51:46 pm »
wondering if that tacho/right angle drive thing comes off the back of the speedo, thereby leaving a standard fitting for the cable as on most tach. that right angle could be just that, or could also be changing the ratio as well?
