Author Topic: DT175 info  (Read 2089 times)
Offline Vince H
DT175 info
« on: July 21, 2014, 03:36:17 pm »
hi can anyone tell me whether or not the engine side cases are the same on the different year models ie is a 76 the same as a 77, 78 , etc. also are other parts interchangeable .cheers
Offline the stig
Re: DT175 info
« Reply #1 on: July 21, 2014, 05:03:01 pm »
     Pretty sure they are
     I used a set of 3eu cases and put all my IT 175 D stuff
     into those cases its the same Fit
    The  Stig
Offline Vince H
Re: DT175 info
« Reply #2 on: July 21, 2014, 05:49:02 pm »
cheers stig
Re: DT175 info
« Reply #3 on: July 21, 2014, 06:46:13 pm »
I think you will find the 125 parts will fit in a lot of times too .
Re: DT175 info
« Reply #4 on: July 21, 2014, 07:10:05 pm »
Monoshock motors are different to twin shock, even though they are based on the same architecture.
WRT the clutch covers, the later ones have a relief for the kick starter return spring, and there's at least one bolt hole in a different spot. They are also visibly different (raw aluminium with recessed "YAMAHA" on the early, black painted with raised "YAMAHA" on the later).
