Author Topic: Rm C forks  (Read 2508 times)
Rm C forks
« on: July 20, 2014, 05:38:51 pm »
Can you run RM C 78 forks in pre 78 as they a follow on from the 77 125 forks?
Offline William Doe
Re: Rm C forks
« Reply #1 on: July 20, 2014, 05:49:42 pm »
There quite different Mick , so i wouldn't think so . C forks were protested at the Connondale nats and the protest upheld .Longer travel and the handlebar clamps are rubber mounted .
Offline David Lahey
Re: Rm C forks
« Reply #2 on: July 20, 2014, 06:20:40 pm »
My RM250C has solid mounted bar clamps. Mine is the first C model (with the alloy tank and steel swingarm)
previous pseudonym feetupfun
Re: Rm C forks
« Reply #3 on: July 20, 2014, 07:27:41 pm »
Well then YZ-D it is then, lets me fit a better brake as well
Offline KTM47
Re: Rm C forks
« Reply #4 on: July 20, 2014, 09:38:52 pm »
If you want to ask an eligibility question, maybe you should ask the commission, through MA.  I have seen a pair of C forks they seem to be the same as the B forks with an aluminium extension on the top.  They may be the same forks modified by Suzuki for extra travel.  It may just be a case of undoing the extension and screwing the fork cap in, other internals may need to change also. The triple clamps however could be a problem.
Either way ask MA, they can say yes or no.
Ted is correct (sometimes) don't ask eligibility questions here.
MAICOS RULE DESPITE THE FOOLS
