Author Topic: Does powder coat harden up?  (Read 4041 times)
Offline Gippslander
« on: July 18, 2014, 10:33:06 pm »
Does powder coat harden up or is it as hard as it ever gets when the job is done?
Re: Does powder coat harden up?
« Reply #1 on: July 18, 2014, 10:36:03 pm »
to the best of my knowledge it stays the same after it cools
Offline Gippslander
« Reply #2 on: July 18, 2014, 10:45:36 pm »
Thanks,  I'm getting some car alloy wheels done a mat grey and the tyre fitter asked because he said if it hardens like ordinary paint we will wait a while before fitting the tyres up
« Reply #3 on: July 18, 2014, 10:49:23 pm »
Once cooled I can pull bits out of the oven and hit them with a rubber mallet if necessary.
Just make sure your powder coater doesn't put it on too thick as it may chip easier
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #4 on: July 18, 2014, 10:53:10 pm »
You should ask your tyre fitter to put rim savers in when fitting, they are like a plastic lip that covers the edge of the rim but they are slippery to allow the tyre to pass over it and removed before inflating.
Ban BLACK rims NOW
Offline Digga
« Reply #5 on: July 19, 2014, 10:14:42 am »
Powder coating is applied via electrostatic gun & will generally be around the 60 - 100 microns in thickness. Think of it as a plastic coating which is applied as a dry powder & fused/melted in an oven generally 30 mins at around 200 - 230 C.
There are various hybrid powder coats around but the main one used will be polyester. Once cured it will be as hard as it will ever get & is always vulnerable to chipping dut to the film thickness & it is a coating always under stress (glass like).
For best performance, the substrate metal should be shot blasted to clean & roughen the surface as a good key base, followed by a suitable chemical cleaning/pre-treatment to help the powder bond better.
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
« Reply #6 on: July 19, 2014, 12:06:31 pm »
No, it's always a cry-baby.
I'm here all week. Try the steak.
Offline bishboy
  • Toowoomba
« Reply #7 on: July 19, 2014, 12:46:49 pm »
Maybe you could give it a spray of this... ;D
« Reply #8 on: July 22, 2014, 10:17:31 am »
Mix blue pills with it ;)
« Reply #9 on: July 22, 2014, 10:29:27 am »
try the steak..  I love it :D ;) haven't heard that one in years....
Offline Gippslander
« Reply #10 on: July 22, 2014, 11:08:56 am »
Thanks for the answers, can now ask the powder coater what he uses and ask if he keeps it to a thin coat
