Clubroom
Tech Talk
RM370 kickstart shaft
Topic: RM370 kickstart shaft (Read 3128 times)
micko
B-Grade
July 14, 2014, 11:01:18 pm »
Does anyone know if a RM400C kickstart shaft is the same as a RM370.
pokey
Arse .. Elbow. Know the difference
Re: RM370 kickstart shaft
July 14, 2014, 11:27:50 pm »
My software says
26211-41201 SHAFT,KICK STARTER
370A
370B
26211-41210 SHAFT,KICK STARTER
RM400C
micko
B-Grade
July 14, 2014, 11:34:43 pm »
Yes part numbers are different but I'm thinking it's just the spline difference (fine to coarse) seals the same diameter etc. Thanks
William Doe
July 15, 2014, 04:11:12 am »
Early 370As had the smaller spline shaft
rocketfrog
Reply #4 on:
July 15, 2014, 11:09:34 am »
Micko, check this bulletin out for more info on the kicker shaft interchangeability
http://www.ozebook.com/compendium/techbuls/SerBulletin%20RM%2027-35.pdf
micko
B-Grade
Reply #5 on:
July 16, 2014, 12:02:22 am »
That's for all the info, much appreciated.
Clubroom
Tech Talk
