Author Topic: piston rings 86 ktm 500  (Read 6459 times)
Offline gra1961
« on: July 10, 2014, 01:34:38 pm »
any one got any leads on 86 2 stroke ktm 500 piston rings nla genuine ,
Offline sleepy
Re: piston rings 86 ktm 500
« Reply #1 on: July 10, 2014, 04:20:59 pm »
What are the dimensions of the rings?  Numbers of rings, width of ring and type of ring(Dykes or flat)
Offline gra1961
« Reply #2 on: July 11, 2014, 06:48:28 am »
2 x rings,flat,89 mm x 1.25 mm
Offline sleepy
« Reply #3 on: July 11, 2014, 10:14:30 am »
Are you sure that they are 1.25mm? Wiseco and Wossner rings are 1.2mm and 89mm is a common size. CR500 honda is 89mm bore.
Offline gra1961
« Reply #4 on: July 11, 2014, 01:24:05 pm »
i went off the size from the ktm parts list but i just measured one of the old ones and yes 1.2mm
Offline sleepy
« Reply #5 on: July 11, 2014, 02:03:14 pm »
Get onto your local shop and ask them to order from Serco or Bike and Bits a set of CR500 std bore rings and happy days.
Offline Luffy
  • Next project
« Reply #6 on: July 14, 2014, 07:16:40 am »
Hi Fred nice brown parcel on way ignition a bit heavy thou.
Offline jurado
« Reply #7 on: July 28, 2014, 10:53:42 pm »
To my knowledge, the CR 500 rings cannot be used in a Mahle/Wiseco ktm 500 piston.
Offline gra1961
« Reply #8 on: July 29, 2014, 06:20:51 am »
this one has a elko piston in it.
Offline sleepy
« Reply #9 on: July 29, 2014, 09:31:24 am »
Just to be clear the Wiseco and Wossner rings are the same dimensions as you listed but I do not know what the dimension of the genuine honda rings are. I should ask what the bore material of the KTM is. The Wiseco-Wossner rings are chrome and will work in a nikasil or iron bore but not in a chrome bore.
