Author Topic: radial finned head  (Read 2452 times)
Offline g465b
radial finned head
« on: July 08, 2014, 10:00:57 pm »
wanted-radial finned head , diaphram for Tillotson HR 114 A carb and aftermarket rack/barbeque to suit hagglunds 293cc Xm72,
also world peace and political leaders who aren't f''ked in the head,thanks[/URL][/img]
Re: radial finned head
« Reply #1 on: July 08, 2014, 10:26:06 pm »
Only just sent one to the tip didn't think anyone would want it . honestly good luck this would be a real chooks tooth job . Iain
« Reply #2 on: July 08, 2014, 10:52:31 pm »
Pretty cool for 73
Single sided swingarm and front end would be good for Pony express events for quickly changing punctures, plus you only need one spare wheel as they are interchangeable.
I would go the Rotax version
The Hägglund XM 72 is a motorcycle from the Swedish manufacturer Hägglund & Söner, which was from 1973 to 1977 built and delivered to the Swedish Armed Forces. In 1974, a venal civilian version was offered. [1]
The prototype of XM 72 Hägglund, the Swedish military, had a two-stroke engine of Sachs with 293 cc displacement, of an automatic continuously variable V-belt transmission and a propeller shaft in the one-sided swing arm drive the rear wheel. The frame consisted of a steel monocoque, the front wheel took a single-arm pushed Short wheel. The wheels were the front and rear the same and interchangeable. The production model of the Hägglund had a conventional telescopic fork, a single-cylinder two-stroke engine with 345 cc, 76 mm bore and stroke (stroke ratio = 1 "squared interpretation"), which was supplied by Rotax. The power was 24 hp (18 kW) at 5.300/min and allowed the 135 kg lightweight bike a top speed of 120 km / h [2]
« Reply #3 on: July 10, 2014, 09:28:09 am »
cant help with smart world leaders either..... :(
