Author Topic: Chrome bores and chrome rings  (Read 15422 times)
Offline William Doe
« on: June 27, 2014, 01:03:15 pm »
What's the go with Chrome bores ? Honda red rockets and YZ 125A models specifically  ???
What rings do you run in them , is it std cast rings in chrome bores and chrome rings in steel bores ?
And what about nikasill and other plated bores , what rings can you run in them ?
Thanks Bill
Offline sleepy
Re: Chrome bores and chrome rings
« Reply #1 on: June 27, 2014, 01:07:58 pm »
Chrome bores - cast iron rings.
Nikasil - cast or chrome rings.
You would be very lucky to find a chrome bore still usable.
« Reply #2 on: June 27, 2014, 01:21:16 pm »
Crazy Phil had his red rocket cylinders replated by NZ cylinders & uses wossner pistons in it, he seems to be really happy with their work. The wossner pistons will be using the same rings as any modern bikes
« Reply #3 on: June 27, 2014, 03:24:22 pm »
There were very few actual models with Chrome bores, the 2 you mention may be the only ones.
Unfortunately every plated cylinder that has a Nicasal bore or Electrofusion bore gets called chrome which causes a lot of confusion.
Nicasal & Electrofusion bores use the same pistons and rings as cast iron bores.
The actual real chrome bores can't use chrome rings otherwise they will seize
« Reply #4 on: June 27, 2014, 03:33:16 pm »
 early Ts 250 had a chrome bore also.
Offline sleepy
« Reply #5 on: June 27, 2014, 04:06:57 pm »
Best thing you can do with a plated cyl is to get it sleeved in cast iron. That's what cylinders are meant to be made off.
Offline mustanggrahame
« Reply #6 on: June 27, 2014, 04:59:57 pm »
Sleeved cylinders don't transfer heat properly. Replating a cylinder is a much better idea.
Offline OverTheHill
« Reply #7 on: June 27, 2014, 05:40:28 pm »
Still kicking myself--a few years ago i decided to give my worn out DT1 GYT kit chrome cylinder [1968] one more run as it always went really well & didn't drop off power when hot like the DT1MX cast bore does [that i have]. Anyway--i Fkd up big time because i picked the 'best of the rest' piston & shuffled around all the old rings [assortment] Knowing full well the right ring must be used & bloody well picked the wrong one. They were all used rings & couldn't decide which was cast but possibly none were, in that box in the end. Short story long--it stuffed it in about 100 metres. Might fix it one day.
Another time back in the  late "60's at a guess a mate had a 'Starmaker' motor[were they villiers?] in a C15, the second model C15 with Ally tank--good looking bike after the goosneck frame that bent. Anyway, he had a chrome cylinder on it  [not sure if aftermarket or came like that but] same story although don't think us budding mechanics knew the implications of running the wrong ring till then. Was an instant learning curve--flat out down our country road & destroyed itself. Damn.
HeavenVMX
« Reply #8 on: June 27, 2014, 05:44:12 pm »
I thought those mid 70's TS250s had a plated bore a bit like the Kawasaki Electrofusion not actually chrome. Could be completely wrong only going on memory from a mates bike.
TZ125, 250, 350 & 700/750 all had chrome bore as far as I know
« Last Edit: June 27, 2014, 05:45:52 pm by HeavenVMX »
Offline Brian Watson
  • First Penton in OZ
« Reply #9 on: June 27, 2014, 05:48:09 pm »
the BSA B44 GP had a chrome bore.. in 1965..
Offline Doc
« Reply #10 on: June 27, 2014, 05:56:04 pm »
yup..'76 TS250A had a Nikasil coating of types called SCEM (Suzuki Composite Electro-chemical Material)
Offline huskibul
« Reply #11 on: June 27, 2014, 06:12:05 pm »
   Didnt yz 125C have a chrome bore , I remember Bitd having the choice of buying a 125C or a red stripe elsinore i opted for the elsie as someone said the C had chrome bore which was bit of a  a put-off - no rebore's   ???
Offline sleepy
« Reply #12 on: June 27, 2014, 06:40:12 pm »
You obviously have never had a sleeve fitted properly.
« Reply #13 on: June 28, 2014, 11:50:08 am »
I reckon so too.
My KDX 175 barrel is buggered and needs replating but you have to give it credit for lasting 33 years on original bore, you won't get a cast iron sleeve do that.
I have a 88 KX 125 barrel that has a steel sleeve fitted, will gladly swap it for a non sleeved barrel in any condition.
« Reply #14 on: June 28, 2014, 02:54:17 pm »
No only the A&B's had the chrome bore's 125 , 250 & 360 .
