Author Topic: Bultaco Questions  (Read 7179 times)
Offline southnztim
Bultaco Questions
« on: June 26, 2014, 02:29:24 pm »
I see for a Mk12 that the piston had windows in them (From what I can make out). Did this occur in all models with the introduction of the reeds? Is it an improvement or would a normal piston do. Any information would be helpful.
Thanks, Tim
Offline Moto
Re: Bultaco Questions
« Reply #1 on: June 26, 2014, 05:30:29 pm »
Hi Tim,
        For the reeds to work ,you need to have the windows in the piston.Its a normal piston with the addition of the windows.
Offline southnztim
« Reply #2 on: June 27, 2014, 03:16:37 am »
Thanks Moto. Do you know the measurements by any chance. I have a piston with the windows, but it looks quite a bit different from a photo of a stock one
Offline sleepy
« Reply #3 on: June 27, 2014, 09:39:52 am »
Is it a 250? I think I have an old piston for one somewhere that I could measure.
Offline southnztim
« Reply #4 on: June 27, 2014, 01:31:37 pm »
No, it's a 370. Thanks for the offer though
« Reply #5 on: June 28, 2014, 01:01:20 am »
sleepy
could you take the measurements for me pls
I have a reed 250 motor coming
Offline sleepy
« Reply #6 on: June 28, 2014, 08:59:29 pm »
sleepy
Strange piston for a Bul.  As best I can measure.
  Dia- 70mm stock
  lenght- 67.5mm(not including the dome)
  dome- 4.5mm
  comp height- 31mm
  pin dia- 20mm
  ring pegs- 30mm either side of center on front
  windows- 2 of 17mm wide, 4.8mm bridge, 29mm high at bridge and 24mm high on the sides. 14.8mm from
  the bottom. All straight edges with about a 4mm radius in the corners.
Hope that helps.
The piston I have measured is a Wiseco but it looks correct for the inlet port.
Offline SON
« Reply #7 on: June 28, 2014, 09:34:51 pm »
If its a Wiseco it should have some model numbers on it
Offline sleepy
« Reply #8 on: June 28, 2014, 10:37:58 pm »
It only has the oversize marking on top which is all they early Wisuco's did. It has 415 on the pin boss which according to an old cataldog should be a Bultaco 250 Astro 77 - 79.
« Reply #9 on: June 29, 2014, 12:09:46 am »
thanks for the info
