Author Topic: Wrecking 1987 CR125 - All parts available  (Read 3453 times)
Simo63
« on: June 25, 2014, 01:18:12 pm »
I have an old and tired 87 CR125 for sale as parts.
The standout part of the bike is the freshly bored cylinder and matching 1.5mm oversize Wiseco Piston kit.  Never started after rebore.
All parts available.
Located Sunshine Coast but can post most parts.
Offline smed
Re: Wrecking 1987 CR125 - All parts available
« Reply #1 on: June 25, 2014, 01:50:33 pm »
PM sent :)
Simo63
« Reply #2 on: August 26, 2014, 09:28:12 pm »
BUMP :)
« Reply #3 on: August 26, 2014, 09:43:37 pm »
Does it have a decent cylinder head? The two i have are both peppered with big end bearing cage by the looks
Simo63
« Reply #4 on: August 26, 2014, 10:04:01 pm »
Will have a look and get back to you Paul :)
« Reply #5 on: August 28, 2014, 08:11:17 pm »
Any luck Craig? You haven't gone Black Ops have you?  ;)
Simo63
« Reply #6 on: August 28, 2014, 08:21:03 pm »
Lol .. Shhhh .... they're listening as we speak
Yeah I did check it out. So the good news is that it's a good cylinder head .. the bad news is that it's bolted to a good cylinder with a new piston and I think you should buy the lot Paul :)
Will work out a deal for you mate with low deposit and 5,000 easy backbreaking payments :)
« Reply #7 on: August 28, 2014, 10:03:12 pm »
As long as it comes with a certificate of authenticity from the Ponds Institute.
Unfortunately i already have a freshly rebored cylinder and new piston all set to go.
Offline jamie ashcroft
« Reply #8 on: August 29, 2014, 06:55:10 pm »
hi i am looking for a few parts for an 88 anything left
Simo63
« Reply #9 on: August 30, 2014, 01:33:36 am »
Most parts still available. Front end gone, rear wheel sold.  What do you need Jamie?
« Reply #10 on: August 30, 2014, 06:48:31 am »
fiddly bits realy simo  rear disk cover white ,chain slider that bolts onto the swing arm at the back ,original clutch perch with rubber boot, a good throttle tube ,original seat and rear fender bolts ,lower chain roller ,renthal bars i am cleaning up an 88 and want to keep it oem parts
