Marque Remarks
Suzuki
TM250/125 tanks
Topic: TM250/125 tanks (Read 2188 times)
Jumbo J
B-Grade
TM250/125 tanks
June 23, 2014, 07:44:36 pm »
anyone onow if a TM125 tank will fit a TM250 with out any bracket mods - on the L and M models?
Re: TM250/125 tanks
June 23, 2014, 07:49:45 pm »
Jumbo..... yes they do fit into front mounts but won't drop into cross bar cushion ( easy fix ) and because tank is shorter rear bracket needs attention.
Nothing too hard to make it fit and no serious mods required
Last Edit: June 23, 2014, 07:51:39 pm by oldfart
Jumbo J
B-Grade
Re: TM250/125 tanks
June 23, 2014, 10:10:52 pm »
thanks for that oldfart - good to know. i'm after a tank for my 250 and havn't had any luck here or anywhere else. But theres a few 125 tanks pop up from time to time. BTW would you also happen to know if a 74 swingarm will fit straight on to a 75 frame without frame modification. i've been told that the 75 has a larger pivot bolt.
oldyzman
250 two stroke!
Re: TM250/125 tanks
June 23, 2014, 10:18:46 pm »
I just put a 125 tank on mine, thing is the seat will come up short of the tank and leave a gap between them. I now need a 250 tank for mine anyway cause the bike is now on methanol and wont last 25 laps dirttrack...
Brett
Simo63
Re: TM250/125 tanks
Reply #4 on:
June 23, 2014, 10:33:30 pm »
Not much Stewy doesn't know about the early Suzukis ... except how to bolt his seat on correctly ...
Marque Remarks
Suzuki
TM250/125 tanks
