Author Topic: 1984 XR250 RE Camshaft wanted...  (Read 4217 times)
Offline Hardo
« on: June 23, 2014, 03:52:36 pm »
Gday all. Looking for a Cam for the 84XR250 RE.
Please dont ask why ...   :o ??? :o
I can get a new one from Partzilla for only $124 USD (which I might do anyway) , but not sure if it will arrive in time for Heaven's next RD at Cessnock.
Please if anyone can help out that would be great.
Hardo
Offline PCMAX
Re: 1984 XR250 RE Camshaft wanted...
« Reply #1 on: June 23, 2014, 04:41:06 pm »
Sorry mate but let me be the first to ask WHY? Maintenance or installation issues?
Try making a request via
http://www.findapart.com.au
It goes out to bike wreckers all over the country, I've had some luck using it in the past.
Pete
Offline mick25
  • Hunter valley NSW
« Reply #2 on: June 23, 2014, 06:18:44 pm »
Bloody hard on the gear HARDO  ;D
Offline Hardo
« Reply #3 on: June 23, 2014, 06:56:22 pm »
LOL Mick ... yes it appears I am... even in the Mancave it seems !!
Thanks for the link Pete.... I have sent my request so we'll see what happens.
Okay then... here it is:
Rattle gun on 10mm bolt = 1; Camshaft lug = 0.
(it was one of those ..'why the faawk was I using my rattle gun then' moments)
HeavenVMX
« Reply #4 on: June 23, 2014, 07:37:06 pm »
looks like it may be past a helicoil saving it as well  :-[ :P :-X
« Reply #5 on: June 23, 2014, 08:02:11 pm »
araldite the bit back in ... good as gold :o... not
« Reply #6 on: June 23, 2014, 08:06:10 pm »
Oxy weld it with nickle bronze and re tap the thread.
Offline topari
« Reply #7 on: June 23, 2014, 08:10:13 pm »
Agree. A machine shop maybe able to do the work for you. Worse case, make a new part.
topari
1979 IT400F, 1984 kdx200
Offline Noel
« Reply #8 on: June 23, 2014, 08:14:54 pm »
PM sent
Noel
Simo63
« Reply #9 on: June 23, 2014, 08:20:33 pm »
 :o :o :o  Yeah WTF were you doing using a rattle gun on a cam bolt Hardo ???
Offline Hardo
« Reply #10 on: June 23, 2014, 08:27:52 pm »
I really dont know Simo ..... As I did it I had that thought of ummmmmmm....
I kind of just had it in my hand and thought I'd go 'gently' ...
 :o
Araldite... LOL  hehehe...
Noel: I cant see any PM ?
« Last Edit: June 23, 2014, 08:34:45 pm by Hardo »
Offline Noel
« Reply #11 on: June 23, 2014, 08:46:08 pm »
re sent
Offline PCMAX
« Reply #12 on: June 23, 2014, 09:15:28 pm »
I had a similar thing happen on an 84 XL250 but I was only using a 1/4 drive ratchet. When I went looking for a new crankshaft I found that many others had experienced a breakage in the same area. It seems to be a common fault and may excuse your heavy handed rattle gun approach.
I did get mine welded with the intention of putting it in the lathe and skimming the surface that mates with the Cam sprocket then using the sprocket to center and drill/tap the hole. Problem was the welder used stellite which apparently is about as hard as diamonds and nothing would touch it.....
Offline Hardo
« Reply #13 on: June 23, 2014, 09:19:44 pm »
Cheers Michael and thankyou Noel. I will take you up on that offer.
I wouldnt have actually thought that was repairable.... sweet !
Yes Pete... that was it for sure !  had NOTHING to do with my poor tool-sense ....  :P
