Author Topic: CR/PE hybrid  (Read 3650 times)
Offline frostype400
Re: CR/PE hybrid
« Reply #1 on: June 21, 2014, 08:48:41 pm »
I like it he has put most of the 400 frame in by the looks of it I have a cr250 front end on one of my pe400's.
1971 tm400 and PE's
Offline frostype400
Re: CR/PE hybrid
« Reply #2 on: June 21, 2014, 08:56:35 pm »
What he could have done was actually use the pe400 frame neck though and put the pe steering stem into the cr triples so he only would have had to modify the back of the frame.
Here is one I am working on.
No chopping though only modified engine mounts and I think I can run original airbox just will be tight.
1971 tm400 and PE's
Offline MaxPower
Re: CR/PE hybrid
« Reply #3 on: June 23, 2014, 11:37:18 am »
The 400 in the 175 frame looks like a good fit.
It would be nice to have 43mm forks to complete it. A might slim the lines of the fat PE tank. But somehow with all those cooling fins stuffed in there the tank looks like it fits the motor now.
Has anyone else done this swap?  You all in Australia respect the PE and IT and KDX a whole lot more than most vintage riders in the US do.
Re: CR/PE hybrid
« Reply #4 on: June 24, 2014, 05:41:39 pm »
the PE was a great little bike for everything. it would do desert, hills, mud and mx ...none of it perfectly but good enough to give it a good run. the quick change wheels were good, the motor was strong once sorted and with a descent pair of rear shox was a great ride.... I liked mine a lot.
Re: CR/PE hybrid
« Reply #5 on: June 24, 2014, 06:05:12 pm »
hi Frosty
the motor looks good in there but im wondering where are you going to stuff the big pipe that a 400 needs coz not much room between the motor and tank on the right hand side, maybe a 250 would be easier to do
Re: CR/PE hybrid
« Reply #6 on: June 24, 2014, 06:28:47 pm »
I rekon grind a few fins of the head and she will fit like a glove
Re: CR/PE hybrid
« Reply #7 on: July 06, 2014, 11:24:37 am »
have ya finished? would luv to see the finished item ;)
Offline frostype400
Re: CR/PE hybrid
« Reply #8 on: July 06, 2014, 03:11:26 pm »
I have done stuff all to that one but my other one is nearing completion got a gmc pipe for it just need the motor now. :)
1971 tm400 and PE's
