Author Topic: Need help rewiring TS points magneto - new primary coil and condensor  (Read 3537 times)
I shoulda taken a pic 'before'!  But....I think it goes:
- primary coil wire to stator plate earth via nut and bolt assembly on points assembly
- wire from condensor to same earth
- wire from condensor out and up to ignition coil.
Anyone know if that's right?
Then.....wire in the kill switch, with a wire to earth and one to the ignition coil wire.
yeah sounds about right ;)
I fink you're right Matt - there were spark!
Took the opportunity to remove all extraneous wiring for lights etc - just wires for spark now, nuffin else.
only ride it during the daytime....
