Author Topic: mx 250/360 parts  (Read 1720 times)
Offline Ekka
  • Go hard or go home
mx 250/360 parts
« on: June 16, 2014, 09:32:58 pm »
New genuine parts to suit a mx 250 74 mod some may fit 360 ( 1 main axle shaft bearing is 360 only $60.00 )
 two pairs of crank seals $40.00 a pair
1 gear shaft seal $ 5.00
1 kick starter shaft seal $10.00
1 pair of crank bearings $120.00
2 main axle shaft bearing $30.00ea
1 pair thrush washers of big end $25.00
1 big end bearing $60.00
1 crank pin $70.00
1 piston pin $20.00
1 piston pin bearing $15.00
1 head gasket $20.00
1 clutch cover gasket $30.00
1 front exhaust bolt with spring $30.00
2 front exhaust bolt no spring $20.00
1 rear hub $250.00
1 pair piston circlips $5.00
non genuine new parts dc side covers and front guard not sure on rear white in colour $50
second hand parts pair original side covers $20.00
barrel bolts $10.00 the set
1 bash plate $40.00
plus postage on sent items at buyer expense pm if u want photos cheers Ek
Offline mposs
Re: mx 250/360 parts
« Reply #1 on: June 17, 2014, 06:27:29 am »
I would like the sidecovers and guards please. PM sent
Offline Ekka
« Reply #2 on: July 06, 2014, 04:31:17 pm »
Side covers sold and dc plastics
Rear hub reduced to $200
All the motor parts $400 the lot
Also found a brand new genuine clutch cable $20
Plus post
