Author Topic: Dt1 Carb Spacer  (Read 3082 times)
Offline von_sieben
    • STOLEN garage co
Dt1 Carb Spacer
« on: June 11, 2014, 09:32:05 am »
Just wondering ... whyt is the huge spacer between carb and cylinder on the dt-1 for? is it really necessary? what effect would it have to remove it apart from having to find some new connection to the airfilter?
There´s no specific reason, just everytime when i work on my bike i´m asking me this question..
any idea?
Re: Dt1 Carb Spacer
« Reply #1 on: June 11, 2014, 10:39:26 am »
Are you referring to the insulator spacer? Heat mainly.
Offline pancho
Re: Dt1 Carb Spacer
« Reply #2 on: June 11, 2014, 12:28:39 pm »
 I would suspect that appart from heat transfer, shortening the inlet port by removing the spacer would weeken bottom end torque,  and also interfere with jet settings,
Re: Dt1 Carb Spacer
« Reply #3 on: June 11, 2014, 06:45:26 pm »
There were 2 types the Enduro as standard and a thinner one that was used with the GYT parts , With jetting changes it helped the motor rev but at a loss of bottom end . Iain
Offline von_sieben
    • STOLEN garage co
Re: Dt1 Carb Spacer
« Reply #4 on: June 11, 2014, 08:42:48 pm »
Thanks. That was my guess, too.
