Clubroom
Tech Talk
Honda CR125 1988 model fork specs
Topic: Honda CR125 1988 model fork specs (Read 2547 times)
smed
June 09, 2014, 06:27:07 pm »
Anybody have a manual? Need to know fork oil weight & height,Racetech website says 5wt at 125mm, correct
Racer X
Novice
Re: Honda CR125 1988 model fork specs
June 17, 2014, 04:17:02 pm »
I have a 1988 500 manual.
169mm min, 114mm max, 123mm (557cc) standard, use ATF or equivalent. Does not specify weight.
Standard springs are soft so you need to change them.
Last Edit: June 17, 2014, 04:34:29 pm by Racer X
smed
June 17, 2014, 10:03:50 pm »
Thanks Man
Clubroom
Tech Talk
