Author Topic: 78 pe 175 exhaust  (Read 3704 times)
Offline reg
78 pe 175 exhaust
« on: May 31, 2014, 11:01:20 am »
has anyone here had experience removing the baffle plate in the guts of the pipe, fair chance
mine is blocked up. thanks reg
Re: 78 pe 175 exhaust
« Reply #1 on: May 31, 2014, 11:19:56 am »
Would a PE have baffles in the main pipe?  I would have thought it just had mesh around the inner wall?  I never had one open so don't know.
« Reply #2 on: May 31, 2014, 11:27:13 am »
FWIW. No baffle plate or restrictors in a 185 pipe apart from the removable baffle at the end
.cant see why one would be in a pe as it would play havoc with the waves in the chamber wouldnt it?
Offline oldmxracer
« Reply #3 on: May 31, 2014, 09:37:48 pm »
I believe the 78 has baffles. Should be able to make out where it's welded from the outside....
« Reply #4 on: May 31, 2014, 09:53:08 pm »
from memory the baffles were spot welded in so look for those before cutting
Offline Glen08
« Reply #5 on: June 01, 2014, 08:45:00 am »
Tuff to remove,  I found it much easier to cut out a section containing the restrictor, so you can get at it from both sides. It's very robust  :)
« Reply #6 on: June 01, 2014, 02:17:57 pm »
lot of flucken around, get a rm125 with stuffed header pipe cut it off weld yours on at the factory join,a lot less welding and mucking around and looks 10 times better ;)
« Reply #7 on: June 04, 2014, 10:02:35 am »
« Reply #8 on: June 04, 2014, 10:12:46 am »
Dare I say it, is that an RM125B optional alloy swingarm on the PE?  Oh, and RM125B forks & rear shocks.
That pic was taken at this years Bonanza.
« Last Edit: June 04, 2014, 10:14:44 am by John Orchard »
