Author Topic: changing slide profiles  (Read 2715 times)
« on: May 25, 2014, 07:51:42 am »
I've put a wanted ad up for a leaner pwk carb slide, alternatively, how tricky is it to change the existing #5 slide I have?
I'm thinking there's 1mm difference between 5,6,7 etc, Is that at the centre of the slide? ie. I wouldn't be taking 1mm off the entire width of the slide, just the centre and then blending it back to the edges?
Re: changing slide profiles
« Reply #1 on: May 25, 2014, 08:06:08 am »
Been done before many times
« Reply #2 on: May 25, 2014, 08:34:43 am »
In the way that I described?
« Reply #3 on: May 25, 2014, 08:39:49 am »
I do it with a belt sander and finish with wet and dry fine grit.
« Reply #4 on: May 25, 2014, 12:18:03 pm »
Round or flat slide?
« Reply #5 on: May 25, 2014, 12:25:27 pm »
PWK flat slide.
« Reply #6 on: May 25, 2014, 12:38:39 pm »
Cut away is a bit wider, the time I did it I scribed with jenny calipers copying the original profile
Offline pmc57
« Reply #7 on: May 25, 2014, 01:10:48 pm »
"Jenny Calipers", haven't heard that description for many years. Also known as Odd Leg or Hermaphrodite Calipers.
Well done Lozza
« Reply #8 on: May 25, 2014, 01:22:05 pm »
Cool, thanks
