Author Topic: machining swing arm pivots  (Read 4110 times)
« on: May 13, 2014, 07:24:46 pm »
As per title .... I have made Bronze bushes, and not too sure what material I should us for the spacer  ( internal sleeve ) that the axle spaces thru.
What are your thought's ???        I have 4140 in mind.
« Last Edit: May 15, 2014, 07:39:03 pm by oldfart »
Offline Lewis
Re: maching swing arm pivots
« Reply #1 on: May 14, 2014, 05:58:42 pm »
recently did my ossa swingarm and just used aluminium bar nothing special(only cos it was a perfect fit) no probs so far.
« Reply #2 on: May 14, 2014, 06:14:29 pm »
How did you pull up the other day ol mate??, im just starting to feel ok! (im not in good shape....)
Offline Michael Moore
    • Euro Spares
« Reply #3 on: May 15, 2014, 01:22:10 am »
I use case-hardened linear shafting.  There are a limited number of diameters available so you may not be able to have a perfect match for the OEM diameter, but that can be accomodated by machining the bushings to match.  The centers are soft.
http://www.mcmaster.com/#linear-shafts/=rynwfy
cheers,
Michael
Offline SON
« Reply #4 on: May 15, 2014, 03:57:17 am »
Correctly lubricated you could use a nylon block.
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: May 15, 2014, 07:35:12 am »
You can harden 4140 by heating it with an oxy and chucking it in oil.
I've done all my huskys with brass bushes and the original hardened center bush.
Works fine.
« Reply #6 on: May 15, 2014, 08:01:02 am »
Steering rack shafts are cheap and hard.....easy to machine....they work real good. ;)
Offline Lewis
« Reply #7 on: May 15, 2014, 10:29:50 am »
felt very old on Tuesday. many aches but I'm ready for another go.
Offline 147
« Reply #8 on: May 15, 2014, 12:37:39 pm »
Machine the sleeve from 4140 then get it nitrided, nitriding doesn,t effect the finished dimensions or distort the sleeve in any way,it will give you about a 10 thou hard case with a high tensile core.
everyone wins a prize 4 stroke dummy class
« Reply #9 on: May 15, 2014, 06:49:23 pm »
"felt very old on Tuesday. many aches but I'm ready for another go."
thank chr8st for that, I thought I was seizing up.. pushing that Villa finished me off...
