Author Topic: DG Vs Pro Form pipes  (Read 26612 times)
Offline William Doe
Re: DG Vs Pro Form pipes
« Reply #15 on: May 13, 2014, 07:00:51 pm »
Why would you bother buying overseas when you can support a local buisness .
GMC products are world class and made in Australia , i dont know what gauge steel Geoff uses but his pipes not only work well , fit well , look good, they are bloody strong . In the unlikley event your not happy , the manufacturer is local , speaks a form of English and is very happy to listen and will modify pipes to your requirements . You are buying direct from the factory ( well casa del Morris ) so no middleman clipping the ticket and bullshiting you that its the suppliers fault .
I have fitted GMC pipes to RM 125B , RM 250 B, RM 370B, YZ 125A , MX 125C, RM 400N and will soon get a couple of KX ones .
His YZ 125A pipe is without doubt the bigest performance mod you can fit to any YZ , MX, DT 125 / 175 twinshocker when coupled with a 34mm  carb and if you want a GMC air box .
Offline VMX Andrew
« Reply #16 on: May 13, 2014, 07:22:06 pm »
Yep have to give GMC a plug as well.
My Maico AW400 and CZ have GMC pipes and look bloody great.
Next on the hit list will be the Maico 490.
Offline Ted
« Reply #17 on: May 13, 2014, 07:24:39 pm »
His second gen. exhaust system for the 125 B is the secret to these things making power.
Contrary to the Neville who lives north of civilisation belief that he R&D it.
81 YZ 465 H   77 RM 125 B
« Reply #18 on: May 13, 2014, 07:28:21 pm »
I will give GMC a plug as well got his pipes fitted to 3 bikes , He also has done my frame fix ups . Iain
Offline VMX Andrew
« Reply #19 on: May 13, 2014, 07:33:42 pm »
They last forever too !
The business badge on my CZ pipe has his old phone number on it that he no longer uses  ;D
Offline Toolboy
« Reply #20 on: May 13, 2014, 09:31:47 pm »
I agree with buying local ..unfortunately GMC does not make the RM250Z pipe or I would of purchased today.
Bear has the ProForm for my 400N
If all else fails I will have to go for the DG pipe, the original fitted has split the seam and waver thin
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
« Reply #21 on: May 13, 2014, 09:51:40 pm »
shame the owner of GMC is such a wally though - suppose you have to put up with that to get the right product though  ;D
« Reply #22 on: May 14, 2014, 09:34:36 am »
1.2mm actually, and yes thicker than most of the stamped chambers
That is relevant to how much Bourbon happens to be in the bloodstream at the time ;D
My current phone number (which is back on line again now) is now 14 years old
I'm only belligerent to you Rosco ;D
Offline BigBanana
« Reply #23 on: May 14, 2014, 10:10:25 am »
Geoff, you don't do a YZ125K pipe do you?
BEARVMX
« Reply #24 on: May 14, 2014, 08:07:31 pm »
photos for son ;D Bear
Offline SON
« Reply #25 on: May 14, 2014, 09:00:34 pm »
Thank you will compare in the morning,
« Reply #26 on: May 14, 2014, 09:34:34 pm »
No I haven't jigged that one yet.
I can do one but you would have to bring your bike in so I could jig from it.
Offline BigBanana
« Reply #27 on: May 14, 2014, 10:51:18 pm »
[No I haven't jigged that one yet.
Hmmm, 2000km is a little far to travel to drop it over...
Anyone around Geoff's area got a YZ125K they could loan him to jig one from?
Offline MaxPower
« Reply #28 on: May 26, 2014, 12:46:23 am »
If it would help anyone I'd be happy to forward a pipe from here in the US
I can write any cost you like on the shipping form however if it had gotten lost or damaged in shipment the shipper will only cover what amount that was claimed.
Someone needs to make vintage pipes. There is clearly a market for them
« Reply #29 on: May 26, 2014, 10:50:01 am »
I need a whole bike to be able to set up properly, jigging from a chamber is a bit hit & miss.
Get the clearance to tight and it won't fit on because it hits on something, get the clearance too loose and it's hanging out in the breeze where it can get damaged easily or just looks shit.
Donor bike doesn't need to be running, it just needs everything where the pipe runs: head, airbox, front guard, fuel tank, original fitting muffler, sidecover and radiators if applicable.
