Author Topic: cr125 87/88/89 cylinders  (Read 2359 times)
« on: May 05, 2014, 10:10:37 am »
I've been told these are all the same, but I'm sure I read back in the day that at least the porting was different on the 88 model?
Simo63
Re: cr125 87/88/89 cylinders
« Reply #1 on: May 05, 2014, 10:21:02 am »
I've got that spare one off my 89 CR125 if you wanted to check it out Paul
« Reply #2 on: May 05, 2014, 12:24:26 pm »
I've been told that the PV is different between all three - so you need the matching ATAC assembly.
No idea if it is correct or not - I might even remember to check one day.
The motors improved (slightly) each year, so I don't foresee an negatives by fitting a later barrell.
« Reply #3 on: May 05, 2014, 12:55:41 pm »
Thanks guys. I remember reading an MXA article on the 88 model where they weren't too impressed with it compared to the 87.
I might see you at the Wyaralong interclub race Craig?
« Last Edit: May 05, 2014, 12:57:24 pm by mainline »
Offline CRTAD313
« Reply #4 on: June 19, 2014, 06:03:32 pm »
Power valve is the same on all three, 89 is nicasil bore others are not.
« Reply #5 on: June 19, 2014, 06:41:26 pm »
Thanks, I ended up finding an 87 cylinder that was only on it 2nd bore so I'm good to go.
