Author Topic: PE175 - sealant recommended on rubber inlet manifold?  (Read 7781 times)
Offline LegOwt
« on: May 04, 2014, 04:06:05 pm »
I'm replacing the inlet manifold on a 1978 PE175 and wondering if I should be using Yamibond or similar when installing. Whats everyone else doing? Like to do job once if possible :)
Offline Glen08
Re: PE175 - sealant recommended on rubber inlet manifold?
« Reply #1 on: May 20, 2014, 04:30:10 am »
Hi,
I use aviation goo or rubber grease...
regards glen.
Offline sleepy
« Reply #2 on: May 20, 2014, 09:42:49 am »
The best is probably 515 loctite flange sealant.
So people use silicone but it goes real funny if petrol gets to it.
If it is a new manifold with a raised up rubber ring then it doesn't need anything other than making sure the mating surface is clean and flat
Offline Digga
« Reply #3 on: May 20, 2014, 10:20:56 am »
L518 is better suited than L515. They are both anaerobic flange sealants (cure in the absence of air) which are applicable for flange gaps < 0.2mm, so if you have such a smooth joint then L518 will be the more sutiable of the 2. However, for intake manifolds, L587 Blue Max silicone is a better candidiate with up to 6.35mm gap fill. All this data is aimed at OEM so for older restorations where things are not so exact, maybe a silicone is more robust. Send me your email address & I'll send you a product catalogue, have a good read through the attachment & you might get a better understanding & choice  ;)
I would post it on here but dont know how to attach a pdf doc  :-\
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Offline sleepy
« Reply #4 on: May 20, 2014, 03:57:03 pm »
Here is a link to the loctite info. Amazing how people can read the same info and come up with different views.
http://www.loctite.com.au/aue/content_data/235564_Do_It_Right_Users_Guide.pdf
It lists the gap fill for 515 as .5mm and is a little slower setting, it is my choice. Also listed as excellent petrol resistance.
Blue Maxx is a good product but is only oil resistant and will not work if liquid petrol or fumes are present.
Offline Doc
« Reply #5 on: May 20, 2014, 05:43:00 pm »
Providing all surfaces are good I've never used anything except a light smear of motor oil ;)
Offline Digga
« Reply #6 on: May 20, 2014, 07:31:00 pm »
Hi Sleepy
The link you have is to the industrial MRO site (maintenance repair & overhaul) whereas I was quoting you from our VRM brochure (vehicle repair mainatence). They are similar but different if you know what I mean. Either way it will work but comes down to waht you are trying to achive & what you are dealing with as this is not OEM.
So we didnt read the same thing & your call on which you choose, was just trying to be of some help  ;D
BTW, if you or someone else can explain how to post/attach a pdf, then I will or sedn me your email address, cheers
