Author Topic: it 250 L or K parting and some other yamy bits  (Read 2208 times)
lms6201
« on: June 23, 2008, 05:54:54 am »
 bottom end (it250k/l)( cases , crank , tranny , nothing outside crankcases) $130,  frame , useable chain ,sprockets ,  , has a 5x8 shock it 175  , light ,    also 36mm forks and clamps , possibly f or g 125   top end(it 250k/l) $130   piston , pin bearing, cyl,  head ,rings  50% life left at a guess ,.5mm o.s. , came off a running bike that lost spark   will trade for 465 yz  bits , stator or charge coil  ,(490 stator or charge coil as well ) throttle top for bevel gear type , or complete later type, sidecovers , new controls even , nice handlebars
« Last Edit: June 26, 2008, 05:45:16 am by lms6201 »
lms6201
Re: it 250 L or K parting and some other yamy bits
« Reply #1 on: June 25, 2008, 05:54:50 pm »
any other swaps for bully or yam 490 /465 bits considered as well
« Reply #2 on: October 25, 2009, 02:30:42 pm »
do you still have the 36mm triple clamps
jim
lms6201
« Reply #3 on: October 26, 2009, 06:06:37 am »
jim i think so , will check soon as i can , where are u located ?
lms6201
« Reply #4 on: November 01, 2009, 07:00:15 am »
engine parts all gone , thanks , a rough frame left , will go to the dump soon i think , there is a swingarm
« Reply #5 on: November 01, 2009, 07:03:56 am »
hi
did you find the triple clamps.i am located in sydney
