Author Topic: Stuff: Axles, clutches, gears, enduro tank, reed blocks, levers, brake bits.  (Read 5146 times)
Lots of wheel axles & some swingarm pivot bolts. Mostly old Yamaha, but some of everything. I don't know what most of them are from, but if you tell me what diameter and length you need, I can check.
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2826_zps7ef98282.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2832_zpsc3a1fa4b.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2828_zpsdce733a8.jpg http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2829_zpsbf32f954.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2830_zpsc6b62196.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2831_zpscc0927c1.jpg
$5 each or $100/lot.
Yellow plastic enduro tank. Grubby as hell, sun faded, looks like it would clean up. Includes questionable cap and tap.
$10.
Sold.
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2919_zps2e172a98.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2918_zps5b1b1cfc.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2920_zpsf329ccc0.jpg
DT125/175 monoshock ignition/sprocket cover x2. Will also suit YZ125D/E (and maybe F?), early IT175, etc.
$5 each.
Speedo & cable. KDX175 or KLX250?!??
$10.
On hold!
Bucket half full of gearbox bits. 99% sure they're RT1 (and DT1?).
$25/lot, will seperate.
sold.
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2915_zps366e7d04.jpg
Numerous clutches. The six-spring ones with the 4-pointed star are RT1/DT1, I think.
The other six-spring one is 39A.
No idea on the other.
$5 each, $20/lot.
Bundle of levers. 2x new DS80 (and lots of other Suzukis) clutch lever blades, about a dozen brand new Gemini lever blades, 2x Magura perches, some sexy plastic levers (Honda, by the looks), bundle of Yamaha ones with the balls broken off, and a number of lucky-dips.
Sold.
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2811_zps71eec217.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2815_zpsdf2cf134.jpg
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2813_zpsba395d4b.jpg
Intake boots.
YZ250K, good condition but a bit hard. $5.
MX250A, good condition. $15.
YZ125X?? Basically junk. Free.
DT250B (appears identical to the MX-A one). Cracked on the outside, not on the inside. $5.
Brand new, NOS YZ125C intake boot, still in the bag. $120.
DT1/RT1 & DT250/360A front brake plates. Includes usable shoes. The one with the arm not fitted has a functional speedo drive. $10/$15.
Other arms, and cams. $5 each, will seperate.
Or $40 for the whole lot.
on hold.
http://i46.photobucket.com/albums/f128/annaandnathan/Bikestuff/BikeOffLoads/IMG_2801_zpsbc255fab.jpg
Also have a front brake plate from a DT125/175 from a late twinshock or early monoshock (non-leading axle forks). $5. (no pic)
YZ125C/X rear brake pedal. Has goofy oversized pedal fitted, but usable.
$10.
YZ125C frame. Minor damage to the rear loop, definitely fixable. Engine and footpeg mounts intact, no sign of repairs.
$30.
Discounts for bulk buys! :)
All in Yass, southern NSW.
Happy to post at your cost (where that's realistic).
Nathan. 0400023847.
« Last Edit: May 12, 2014, 10:02:50 am by Nathan S »
Offline Canam370
Hey Nathan. I'd be innerested in the Magura perches - and lever blades if you had some.
Speedo sold, pending payment.
Paul, There's a moderately bent shorty clutch lever blade included. $15 posted for both perches & the one lever?
Simo63
Nathan I'd be interested in all the good clutch levers (eg the ones not bent and complete with the ball ends) including the magura ones as well.  Can pick up from you at Toowoomba.
Craig
Offline Canam370
Thats fine Nathan, I'll take them. Call you tomorrow.
Offline Tex
PM sent.
Gday Nathan, have ya got an axle, size 19.87 (20mm) o.d x 300 mm long shaft includeing thread but not head, spacers and nut to suit would be great, cheers
Axles and brake stuff on hold.
Levers sold.
Tank sold.
Parts picked up  ;) by new owner.
Great stuff, thanks for your help Stewie. :)
Offline yamaico
Hey Nathan, did you sell all the axles?
Pete.
I have a bloke who said he'll take what's left in a fortnight.
So he's got dibs on the whole lot, but if you want a specific one, then I'll help if I can.
Offline yamaico
I would have taken the whole lot as well but I should have spoken up earlier. They're always handy for the "projects".
No problem, thanks anyway.
Original post updated. Some of this will hit the bin if not spoken for soon...
