Author Topic: YZ465 float compatability  (Read 6962 times)
« on: April 12, 2014, 02:47:28 pm »
Have had the repaired float in my 465h start leaking again & ordered a new 1 through boats.net, was listed as available still but 3 weeks later they've come back to me with not currently available & no idea of whether Yamaha will get more made
Is there a plastic float from a later bike that fits & is still available new?
Re: YZ465 float compatability
« Reply #1 on: April 12, 2014, 02:55:56 pm »
Google the part # to see
« Reply #2 on: April 12, 2014, 03:02:29 pm »
This is what it lists as fitting, large number of bikes up until the 97 WR250
http://www.boats.net/parts/detail/yamaha/Y-2N7-14185-00-00.html
« Reply #3 on: April 12, 2014, 03:11:35 pm »
Found 1 on ebay, hopefully it will last but I'm still keen on finding out if a plastic float set can be fitted
Offline rileyp
« Reply #4 on: April 12, 2014, 03:52:36 pm »
I was just about to suggest boat.net or partzilla as they list all bikes that use it.
http://www.partzilla.com/parts/detail/yamaha/YP-2N7-14185-00-00.html
« Reply #5 on: April 12, 2014, 05:48:45 pm »
« Reply #6 on: April 12, 2014, 06:07:16 pm »
Try the Mikuni dealer in Aust.
Offline b490
« Reply #7 on: April 12, 2014, 10:05:36 pm »
 Ian Williams Tuning  in Adelaide . (08) 8340 928
  Mikuni  carbs / parts  ;  may have what you need .
 Regards ,
                     Steve
Offline brent j
« Reply #8 on: April 12, 2014, 10:11:48 pm »
Is the float plastic or brass Tony?
I found the hard way that if you add ANY solder to a brass float to repair it it floats much lower and stuffs up your float/fuel level
Drop the repaired float(s) in petrol and see if there is any difference in bouyancy
Offline YZ250H
  • Back in QLD Baby !
« Reply #9 on: April 13, 2014, 07:57:51 am »
Wouldn't any VM38SS float do the trick  :-\
Try TD Hadrick in Townsville www.mikunioz.com.au
I haave found them to be pretty good.
« Reply #10 on: April 13, 2014, 03:26:42 pm »
Float is brass.
Original had a hole rotted through the bottom of 1 float, got hold of a 250j carb for parts which had a good float but it cracked last year, had bought repaired by a jeweler mate but he missed the crack but redid it in the week before the johnny old
Will try the float out the vm36 on my CZ when I get time, hadn't thought to try it & not sure if the floats aren't seperate, if it fits then I'll look at getting another
This is the listing for the float I bought, see how many different bikes it fits
http://www.ebay.com/itm/221329519597?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
« Last Edit: April 13, 2014, 03:29:18 pm by tony27 »
Offline brent j
« Reply #11 on: April 13, 2014, 03:55:14 pm »
Float is brass.
The one I repaired was a pair of floats on the bar, usual style. When i dropped them into a container of petrol one side floated, one side sank. Brass floats float quite deep so it doesn't take much to sink them
Offline rileyp
« Reply #12 on: April 14, 2014, 07:22:13 pm »
This guy is very upfront showing prices etc which is weird in Australia
http://www.iwt.com.au/mikparts1.htm
He even has float prices :)
http://www.iwt.com.au/mikparts2.htm
Cheers Pete
« Last Edit: April 14, 2014, 07:25:20 pm by rileyp »
Offline ARN
« Reply #13 on: April 15, 2014, 06:21:44 pm »
hi all
I have both options if you are still needing
the bowl with plastic floats will go straight onto your carby only difference can be breather pipe not going straight up but on an angle ,you can modify plate attached to carby to clear
cheers arno
